Results 1 to 9 of 9
Thread: Laser cutting machine cuts thick metal - GIF
Hybrid View
    May 2024
    emu roo (Jun 3, 2025), nova_robotics (Jun 8, 2025)
    Lake Tahoe
    IntheGroove's Tools
    My bet is oxy-acetylene...
  4. The Following 3 Users Say Thank You to IntheGroove For This Useful Post:
    mwmkravchenko (Jun 3, 2025), nova_robotics (Jun 8, 2025), RetiredFAE (Jun 3, 2025)
    Quote Originally Posted by IntheGroove View Post
    not oxy-acetylene. with the cutting tip that close to the work piece most likely oxy- map gas of even natural gas Too many flames for act either most will only have a max of six 4 for thinner and as few as two for cutting real thin in straight line or slicing rivets
    hemmjo's Tools
    For sure NOT laser.
  8. The Following 2 Users Say Thank You to hemmjo For This Useful Post:
    IntheGroove (Jun 3, 2025), mwmkravchenko (Jun 3, 2025)
    May 2018
    Boring, OR
    CharlesWaugh's Tools
    From: The FABRICATOR (an industry magazine for the metal fabrication trades)
    "For material 3 in. and thicker, the answer is usually pretty straightforward. Typical laser cutting operations handle material up to about 1 to 1.25 in. thick. Plasma cutting’s upper limit is between 2 and 3 in. For extreme thicknesses of steel plate—4, 6, 8, and even 10 in.—oxyfuel cutting is truly at home."
    Charles Waugh
    www.charleswaugh.com
  10. The Following 2 Users Say Thank You to CharlesWaugh For This Useful Post:
  11. #6
    Perth Ontario Canada
    Flames coming out of the tip were my give away. LASER cutting can be up to 150mm or about 6 inches. But the Kerf is Tiny. Power input for such a LASER is roughly 7 times the LASER rating. So we are talking enough for a couple thousand homes when cutting that thickness of metal. And LASERS use an Oxygen stream too.
    Pretty nice cut. I agree with Frank that it's Natural Gas. For the quantities that you would be pouring into such a process natural gas makes the most sense. Imagine the Gas and Oxygen bills for that place!
    Mark
  12. #7
    hemmjo's Tools
    I am trying to imagine the cost for that hunk of steel.
    It seems there would be much more cost effective ways to make letter. Unless that “D” is just shown for a visual effect?
  13. #8
    Plate steel right now is running from 1 to 3 dollars per pound depending on thickness quantity and supplier
    Recently I bought a 4ft by 4 ft 2" plate 80 lbs per ft 16 total sq feet cost me $1,600.00
    That plater being cut is about 4 inches thats 160 lbs per sq ft not cheap
  14. The Following 2 Users Say Thank You to Frank S For This Useful Post:
    hemmjo (Jun 3, 2025), mwmkravchenko (Jun 3, 2025)
  15. #9
    Lake Tahoe
    IntheGroove's Tools
    I have been enlightened. The term I was looking for is Oxyfuel. Thank you Frank...
    [https://www.thefabricator.com/thefab...y-thick-plate]
