Results 1 to 6 of 6
Thread: Line boring bar stabilizers
    the line bore bar worked great even with the Hodge-podge set up however seeing that I could only take a very small cut even using the steady rest to assist in stabilizing the boring bar I Decided what I needed was stabilizer bearings like those I always used on any of my old boring bar setups
    Enter a couple of bearings a pair of housings machined to fit and a pair of shaft adapters which are changeable for different diameter boring bars
    Tack weld these to the sides of thje part being line bored and instantly I can take deeper cuts without fear of the whole thing jumping around on the lathe
    Line boring bar stabilizers-20170629_123159aa.jpg Line boring bar stabilizers-20170629_161546aa.jpg Line boring bar stabilizers-20170629_161553aa.jpg Line boring bar stabilizers-20170630_110654aa.jpg Line boring bar stabilizers-20170630_113034aa.jpg
    It helped having the 100 year old lathe running so I didn't have to remove the set up from the other one to make these
    NortonDommi (Jul 2, 2017), Paul Jones (Jul 1, 2017), Seedtick (Jul 3, 2017), Toolmaker51 (Jul 2, 2017)
    thanks might have to try it
    Oh Honey?
    See, right there Dear;
    Even Frank S need's two lathes. I bet he's not the only one.
    Can I? Can I? Can I?
    Oh Honey?
    Actually I have 3 lathes but one is packed away still awaiting transport
    I have 4 band saws as well But what I really want is a `12" column 5 ft arm radial drill but the one requirement I absolutely insist on is a table mounted on the column that raises and can be swung out of the way and with at least a 4 inch quill 8 inch travel and a #40 taper I can wait
    Thanks Frank S! We've added your Boring Bar Stabilizers to our Machining category,
    the stabilizers and the boring bar reopens an old venue in Line boring for me. Now I will have to get busy and make several more boring bars plus add several more places in this one to hold cutters, and make a portable machine to power the boring bar only this time instead of something like my Du-more versi mill I want to make it with variable speed and power feed
