Line boring machine. By Build and Rebuild. 16:06 video:
Yes the concept is working but rigidity is the issue. You need support nearer the machining areas. Picture turning a long shaft in a lathe where you need a steady rest. In this case, you need support very near where you are machining the bushes. You only need enough clearance to service the cutter and check measurements.
emu roo (Dec 30, 2025)
