Results 1 to 6 of 6
Thread: Log jinker, cant hook or peavey
    olefella's Avatar
    olefella's Tools
    This shifts logs up to 7m x 750mm x 2 tonnes into the Lucas mill (or to shift anything heavy). The tongs are used to lift the log off the ground to sling the chains underneath.
    At the end is shown a 'cant hook', or 'peavey', used to roll logs.
    There are no plans, I made it out of available scrap. The main beam is 90 x 90 x 3.5 square section, sliding into slightly larger sections at each end and a separate section for the middle hoist. Holes in the beam allow 2 long bolts to fix the end frames on the main beam at the chosen length. The end frames are made from square section steel 50-75mm x 3-5mm, with appropriate bracing. The wheels are off an old trailer. Chain winches are 2 tonne.
  2. The Following 6 Users Say Thank You to olefella For This Useful Post:
    baja (May 28, 2019), Beserkleyboy (May 27, 2019), Jon (May 27, 2019), rlm98253 (May 27, 2019), Scotsman Hosie (May 28, 2019), Seedtick (May 27, 2019)
    Thanks olefella! We've added your Log Jinker to our Logging category,
    as well as to your builder page: olefella's Homemade Tools. Your receipt:
    Supporting Member Beserkleyboy's Avatar
    Aug 2014
    Beserkleyboy's Tools
    Great device, olefella! I remember a similar jinker that an 'old fella' in Northern California built to do much the same thing back in the 70s, but his was a 4 wheeler, sort of like a homebuilt lumber carrier... Where abouts are you? Cheers
    Jim - Sth Coast NSW
    olefella's Avatar
    olefella's Tools
    Quote Originally Posted by Beserkleyboy View Post
    Jim - Sth Coast NSW
    Jim - Tasmania
    Aug 2014
    Thanks. Always easy to spot an Aussie invention/inventor here! Cheers
    Feb 2018
    Never heard the term Jinker before. I have a trailer made for a big propane company to move tanks. It is a horseshoe open back frame. 4x4x3/8 thick tube with an arch over the middle equiped with a big hand winch. When the tank is lifted high enough you slide cross pieces under it and lower it down onto them. It has short torsion axles under each side. Best 75 dollars I ever spent!
    Rob
