Results 1 to 5 of 5
Thread: Long boring D bit
    Jul 2014
    France, Brittany !
    Christophe Mineau's Tools
    Long boring D bit
    Here is another use case of my hand chuck, it is for holding a long boring D bit
    Here is how the D bit is made : it's a piece of HSS round stock, ground to shape, that is silver brazed to a rod of standard steel. The tip has a D shape section, that is to say it is ground just above the diameter line. The tip is also ground at a maybe 30° angle, if you look at it from the top :
    Here it is in use on the lathe, through the tail stock, hold by hand with my hand chuck.
    You need a steady rest and you need to drill first a guiding hole in order to drive the D bit at the begining.
    The progress is quite slow, you need to be patient. You push for maybe 5 to 10mm, sometimes less, and you remove the bit to clean up the chips that strick together on the flat section of the bit.
    I frequently soak the bit in a bottle of lin seed oil in order to lubricate.
    And here is the result, through a 40cm long piece of cherry. This is the output end, you can see that I am only maybe 5 mm off center, which is a quite good result.
    No need to say that with a twist bit, this result is nearly impossible, you woold be way more off center.
    The piece is then trued up between centers on the lathe.
    Cheers !
    Christophe
    Facebook : La Belle Note
  2. The Following 10 Users Say Thank You to Christophe Mineau For This Useful Post:
    Andyt (Jun 19, 2019), baja (Aug 14, 2025), CedarSlayer (Dec 2, 2014), Doc (Dec 3, 2014), emu roo (Aug 8, 2025), high-side (Jun 18, 2019), JD62 (Mar 25, 2017), johncg (Aug 25, 2023), kbalch (Dec 2, 2014), Paul Jones (Jan 3, 2015)
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks Christophe! I've added your Boring Bit to our Wood Lathes category, as well as to your builder page: Christophe Mineau's Homemade Tools. Your receipt:
  4. The Following User Says Thank You to kbalch For This Useful Post:
    Feb 2013
    South of Brazil.
    Hotz's Tools
    interesting tool.
    Sorry my mistakes in english.
  6. The Following User Says Thank You to Hotz For This Useful Post:
    Doc
    Doc is offline
    Supporting Member Doc's Avatar
    May 2013
    Doc's Tools
    Very useful tool
    Doc
  8. The Following User Says Thank You to Doc For This Useful Post:
    Haven't seen an application like this before. Needless to say, I found it quite interesting.
    Download plans for milling tools.
  10. The Following User Says Thank You to DIYer For This Useful Post:
