Results 1 to 5 of 5
Thread: Machinist Level Access Cover Removal
    May 2014
    Del Mar, California
    Paul Jones's Tools
    Calibration adjustments to my machinist level can be made after removing a round-sided access cover. The original access cover was very difficult to remove. I modified the original access cover and made a tool making it much easier to remove the cover. The cover already had a small groove around it’s perimeter that I enlarged to fit a standard 3/32” thick No. 115 O-ring. This provided a snug fit but yet easy to remove. I created a screw-on handle that fits into an existing brass thread insert installed on the face of the original cover. The threaded-end handle also served as a mandrel for holding the cover while machining the larger O-ring groove. The handle was made from 0.250” 2011-T3 aluminum rod and a clamp-type knurling tool produced the knurls. The clamp-type knurling tool is a better choice than the traditional plunge knurling tool when working with small diameter aluminum rod.
    Attached Thumbnails Attached Thumbnails Machinist Level Access Cover Removal-tool-removing-access-cover-machinist-level.jpg   Machinist Level Access Cover Removal-machinist-level-access-cover-removal-tool.jpg   Machinist Level Access Cover Removal-modified-access-cover-machinist-level.jpg   Machinist Level Access Cover Removal-before-enlarging-groove-fit-o-ring-.jpg
  2. The Following User Says Thank You to Paul Jones For This Useful Post:
    kbalch (Apr 27, 2015)
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks Paul! I've added your Machinist Level Access Cover Removal Tool to our Machining category, as well as to your builder page: Paul Jones' Homemade Tools. Your receipt:
    Great work on that cover! Had me smiling as I read your post.
    Supporting Member Catfish's Avatar
    Oct 2013
    Mariposa, California
    Catfish's Tools
    Another nice tool Paul. Randy
    May 2014
    Del Mar, California
    Paul Jones's Tools
    Thanks Randy. This may sound funny but the first time a tried removing the access cover I really thought it had a retaining spring connected from the inside. It kept snapping back into place each time I tried pulling it off. It finally came off but I decided to fix the problem so I didn't have to deal with the hassle again.
