Thread: MAGNETIC WELDING GROUND!!
    May 2020
    orioncons36's Tools
  2. The Following 5 Users Say Thank You to orioncons36 For This Useful Post:
    bruce.desertrat (Sep 14, 2021), Home-PC (Sep 17, 2021), kboy0076 (Sep 19, 2021), lassab999 (Sep 15, 2021), nova_robotics (Sep 18, 2021)
    Thanks orioncons36! We've added your Magnetic Welding Ground to our Welding category,
    as well as to your builder page: orioncons36's Homemade Tools. Your receipt:
    nova_robotics's Tools
    Why do you need the threaded rod and the spring? If you remove the spring loaded rod and connect the ground wire directly to the steel flat bar you'll get a better ground. Those neodymium magnets are pressed hard against your workpiece (much harder than the spring loaded threaded rod) and they're good electrical conductors. I think the threaded rod and spring is holding you back.
    I have a magnetic ground that's just a mag base with a ground wire hard bolted to it. It works great.
    Supporting Member projectswithrich's Avatar
    Sep 2021
    USA
    projectswithrich's Tools
    That is an interesting idea. I also wonder what the difference would be if the lead were connected directly to the flat bar. There are several magnetic clamps on the market that do use a spring and there are quite a few that do not. I would assume that on much higher amperages more surface are would be beneficial but for most uses there may not be a difference.
    My Youtube Channel:
    Projects with Rich - YouTube
