https://youtu.be/3jvhlRzDtNk
Thanks warsztatOdZera! We've added your Chain Drive Differential to our Automotive category,
as well as to your builder page: warsztatOdZera's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-chain-drive-differential"> <img src="/uploads/256374/homemade-chain-drive-differential.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-chain-drive-differential">Chain Drive Differential</a> <span> by <a href="https://www.homemadetools.net/builder/warsztatOdZera">warsztatOdZera</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/rearend'>rearend</a> </div> </div> </div> </div>
How do you fill and check the lube level...
It would appear he is going to rely on hard grease for lubrication. This would be fine for the type of unit he made as every thin is almost in the same constant rotation only differing when making turns causing 1 wheel to over run or under run the other.
I would be more concerned with adding the snap ring retainers to secure the axles to the spider gears. This can be accomplished on at least 1 of the axles during assembly, The other side shouldn't be a problem either since there is room behind the pillow block bearing.
All in all it is a great idea
Congratulations warsztatOdZera - your Chain Drive Differential is the Homemade Tool of the Week!
This is very nicely made, and it will be interesting to see what it ends up in.
Micrometer Anvil by Occasional machinist
Machinist's Hammer by AB-SHOP
Sandblasting Gun by PowerMk
Downdraft Sanding Box by e_m_maker
Briquettes by Mr.DK DIY
Mill Table Stops by mr_modify1
3D Printed Cable Sheath Stripper by Carnel
warsztatOdZera - you'll be receiving a $25 online gift card, in your choice of Amazon, PayPal, or bitcoin. Please PM me your current email address and gift card choice and I'll get it sent over right away.
This is your 8th Homemade Tool of the Week win. Here are all of your Homemade Tool of the Week winning tools. Congrats again :thumbsup:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/diy-magnetic-drill-microwave-72178#post130462"> <img src="/uploads/222214/homemade-magnetic-drill.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/diy-magnetic-drill-microwave-72178#post130462">Magnetic Drill</a> <span> by <a href="http://www.homemadetools.net/builder/warsztatOdZera">warsztatOdZera</a></span> </div> <div class="tags">tags: <a href='http://www.homemadetools.net/tag/magnet'>magnet</a>, <a href='http://www.homemadetools.net/tag/drill'>drill</a> </div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/making-multifunctional-drill-press-table-78564#post155221"> <img src="/uploads/231153/homemade-drill-press-table-44.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/making-multifunctional-drill-press-table-78564#post155221">Drill Press Table</a> <span> by <a href="https://www.homemadetools.net/builder/warsztatOdZera">warsztatOdZera</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/table'>table</a>, <a href='https://www.homemadetools.net/tag/drill-press'>drill press</a>, <a href='https://www.homemadetools.net/tag/casters'>caster(s)</a> </div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/making-electromagnetic-vise-79142#post157571"> <img src="/uploads/232563/homemade-vise-20.png"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/making-electromagnetic-vise-79142#post157571">Vise </a> <span> by <a href="https://www.homemadetools.net/builder/warsztatOdZera">warsztatOdZera</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/vise'>vise</a> </div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/making-hydraulic-lift-table-80768#post163610"> <img src="/uploads/234789/homemade-hydraulic-lift-table.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/making-hydraulic-lift-table-80768#post163610">Hydraulic Lift Table</a> <span> by <a href="https://www.homemadetools.net/builder/warsztatOdZera">warsztatOdZera</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/table'>table</a>, <a href='https://www.homemadetools.net/tag/hydraulic'>hydraulic</a>, <a href='https://www.homemadetools.net/tag/lifting'>lifting</a>, <a href='https://www.homemadetools.net/tag/casters'>caster(s)</a> </div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/homemade-metal-cutting-machine-81363#post165973"> <img src="/uploads/235353/homemade-chop-saw-18.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/homemade-metal-cutting-machine-81363#post165973">Chop Saw</a> <span> by <a href="https://www.homemadetools.net/builder/warsztatOdZera">warsztatOdZera</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/saw'>saw</a>, <a href='https://www.homemadetools.net/tag/metalworking'>metalworking</a> </div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/homemade-electric-workshop-crane-82539#post170196"> <img src="/uploads/238048/homemade-workshop-crane-4.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/homemade-electric-workshop-crane-82539#post170196">Workshop Crane</a> <span> by <a href="https://www.homemadetools.net/builder/warsztatOdZera">warsztatOdZera</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/crane'>crane</a>, <a href='https://www.homemadetools.net/tag/battery'>battery</a>, <a href='https://www.homemadetools.net/tag/winch'>winch</a> </div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/making-stump-grinder-86315#post185105"> <img src="/uploads/249967/homemade-stump-grinder-3.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/making-stump-grinder-86315#post185105">Stump Grinder</a> <span> by <a href="https://www.homemadetools.net/builder/warsztatOdZera">warsztatOdZera</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/farm-tools'>farm tools</a> </div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/making-chain-drive-differential-93020#post210654"> <img src="/uploads/256374/homemade-chain-drive-differential.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/making-chain-drive-differential-93020#post210654">Chain Drive Differential</a> <span> by <a href="https://www.homemadetools.net/builder/warsztatOdZera">warsztatOdZera</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/rearend'>rearend</a> </div> </div> </div> </div>
Last century, used to make chain drive diffs out of BMC FWD diffs. Didn't bother making new carriers, just made a Al cylindrical cover to fit carrier, see 51 seconds.
Machined carrier for o ring grooves for sealing... Sprocket bolted on instead of ring gear.
Wire snap rings are standard automotive practice for inner axle retaining... They will disengage with the use of a sliding hammer...
I do consider that he is a trifle optimistic on the lube side, however, considering he fitted oil seals.
