Making a Fixture Plate and Boring Bar
Making a Fixture Plate and Boring Bar for the Cement Mixer Restoration. The Fixture Plate is a dual purpose. Size is 28" x 20" x 1" A36 steel plate. I have made it to fit on my milling machine for large and difficult part mounting. The main purpose for the Fixture Plate is to be used a welding table. I have patterened the holes in the fixture plate following the 2" x 2" with 5/8" holes. I have also made the 5/8" dia portion of the hole 5/8" deep then the bottom fo the hole is drilled and tapped for 1/2"-13 thread. The threaded portion is for using the standard milling machine table strap clamp system which use 1/2"-13 studs.
Please Subscribe: Randy Richard In The Shop: https://www.youtube.com/user/Catfish6945
Video Link: https://youtu.be/sesMo16haqw
I complete the making of the Boring Bar setup for turning the journals on the Cement Mixer Yoke. This is for the restoration of the Vintage Cement Mixer. The first part of making the Boring Bar was done in a Live Feed, Please watch that to see it made live, link below.
Live Feed Link: https://youtu.be/eaKD4CRsrWE
Setup Blocks : Fireball Tools: https://fireballtool.com/
Follow me On Instagram: https://instagram.com/rrintheshop/
Dovetail Cutter and Scribe info: Email To:
RRINTHESHOP@GMAIL.COM
