Des; Have you tried to contact Bob the welder in Ballina 02 6681 3393 He may be able to locate them for you or direct you to where you can find them.
Cigweld is an Essab brand this link may direct you
https://www.bing.com/ck/a?!&&p=51933...JvbGxzLw&ntb=1
Anning if it welds for a while and shuts down a few have found the transformer on the PCB had an intermittent short replacing the 12va transformer with a slightly larger Va rated one solved the issue. connecting the machine to a circuit on the mains with a higher amperage rating has helped others. Any of these smaller machines no matter the manufacture does not fare well with voltage drop from line loss. I've had Telwin, Hobart, Miller, Lincoln, and numerous other brand units, that would die because of trying to use them on too long of a small diameter extension cord. Line voltage loss is a huge killer of anything.
