Metal Miter Saw Material hold down clamp. Made from 5/8 steel rod and 5/16 threaded rod,
and 1 x1x1/8 inch square tubing.
Attachment 2981Attachment 2982Attachment 2983
Very nice ..
:hattip:
A stop and a hold down. Clever additions to that miter, sir!
Yea some times you just got to hold em down...:O):lol:
Hi captain,
You actually cut metal with a wood mitter saw or is it a special one designed for metal ?
Is it a 230mm angle grinder disk ?
Interresting !
Thanks Captainleeward! I've added your Miter Saw Hold Down Clamp to our Metalworking and Clamps categories, as well as to your builder page: Captainleeward's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="/miter-saw-hold-down-clamp"><img src="/uploads/110468/miter-saw-hold-down-clamp.jpeg" alt="Miter Saw Hold Down Clamp" /></a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="/miter-saw-hold-down-clamp">Miter Saw Hold Down Clamp</a> <span> by <a href="/builder/captainleeward">Captainleeward</a></span> </div> <div class="tags"> tags: <a href="/tag/saw">saw</a>, <a href="/tag/clamp">clamp</a>, <a href="/tag/miter">miter</a>, <a href="/tag/hold-down">hold down</a> </div> </div> </div> </div>
Nice design for the clamps. I use a Diablo 10-Inch 80 tooth TCG non-ferrous metal saw blade to cut through aluminum stock but use need good clamps like yours to securely hold the aluminum. Can't take any chances with the set up. The aluminum cuts like butter and has a mirror finish.
Hay Paul , I cut mostly steel with mine . since I have been welding steel I have dropped aluminum for steel as I don't have the spool gun to weld aluminum. I try to use my band saw as much as possible as the cuts are really good. this saw works best when I have a lot of angles to miter and the metal not more than 1/8 inch thick. Some grinding required.
Attachment 2990
Good to know. When I am not cutting aluminum, I swap the Diablo non-ferrous blade for a reinforced abrasive cutoff wheel but have to move the miter-saw outside because cutting steel with my abrasive wheel seems to permeate the garage with the smell of burnt cordite and a lot of explaining to the family.
OH YA OUTSIDE is the way to go always....:O)
That's a nice addition.
