Results 1 to 10 of 10
Thread: Method for bending a tight set in solid bar
    Berkshire UK
    thehomeengineer's Tools
    Hi All
    This is a method I use to bend solid bar which works really well when a tight radius is required. I had to put a set in a piece of 12mm diameter bar for the handle on my retractable screw cutting tool holder. (for three reasons) To give better vision when external screw cutting, secondly to move operators hand further away from the chuck when retracting the tool and thirdly to miss one of the clamp screws.
    Method;
    Firstly, you notch with a file where the inside radius of each bend will start along the bar. In this case I also had to take in consideration the orientation as the bar screwed in to a housing. The bar can then be set in the vice with the notch vertical and at the edge of the vice jaw. The bar is then heated until red and a piece of tube slid over to aid leverage to bend the bar. Due to the notch, this is where the bend will be formed about. The process is repeated for the second bend to create the set.
    First photo shows notch cut with the bar screwed into the housing so the orientation of the handle is correct
    Method for bending a tight set in solid bar-img_0825-copy.jpg Method for bending a tight set in solid bar-img_0826-copy.jpg Method for bending a tight set in solid bar-img_0827-copy.jpg Method for bending a tight set in solid bar-img_0828-copy.jpg Method for bending a tight set in solid bar-img_0850-copy.jpg Method for bending a tight set in solid bar-img_0829.jpg
    Thank you for taking the time to read
    The Home Engineer
    Last edited by thehomeengineer; Feb 19, 2018 at 03:39 PM. Reason: photo discription
  2. The Following 25 Users Say Thank You to thehomeengineer For This Useful Post:
    Andyt (Oct 25, 2018), baja (Mar 17, 2022), bgerens (Feb 21, 2018), carloski (Mar 16, 2022), drivermark (Feb 21, 2018), Eaglewood (Jan 24, 2019), high-side (Oct 25, 2018), JD62 (Feb 20, 2018), Jon (Feb 21, 2018), J_P (Mar 2, 2018), Paul Jones (Mar 4, 2018), PJs (Feb 20, 2018), Priemsy (Feb 21, 2018), Ralphxyz (Mar 17, 2022), rayh__ (Apr 4, 2023), rgsparber (Jan 25, 2019), rlm98253 (Feb 20, 2018), Scotsman Hosie (Mar 3, 2018), Seedtick (Feb 20, 2018), that_other_guy (Jan 24, 2019), tuchie (Feb 27, 2024), UncleBob (Jan 24, 2019), uv8452 (Feb 10, 2023), verticalmurph (Feb 10, 2023), volodar (Jul 2, 2018)
    Supporting Member frugalolegeezer's Avatar
    Nov 2015
    Mound City
    frugalolegeezer's Tools
    Man I sure thank you for that tip. Over the years I had trouble bending two bars at the same place and now I can see this method will be a great improvement in my shop.
  4. The Following 3 Users Say Thank You to frugalolegeezer For This Useful Post:
    jayzauto1 (Aug 4, 2022), Paul Jones (Mar 4, 2018), thehomeengineer (Feb 21, 2018)
    Supporting Member Scotsman Hosie's Avatar
    Apr 2017
    Salt Lake City, UTAH
    Scotsman Hosie's Tools
    Sweet. Works better than I would've guessed.
  6. The Following 2 Users Say Thank You to Scotsman Hosie For This Useful Post:
    Paul Jones (Mar 4, 2018), thehomeengineer (Mar 3, 2018)
    Thanks thehomeengineer! We've added your Bar Stock Bending Method to our Metalworking category,
    Dec 2017
    Cape Coral, FL
    old_toolmaker's Tools
    thehomeengineer,
    Thanks for the tip! It sure looks like a good way to get the bends to occur where they are wanted.
    Dick
    Links to some of my plans:
  9. The Following User Says Thank You to old_toolmaker For This Useful Post:
  10. #6
    Dec 2015
    Quote Originally Posted by thehomeengineer View Post
    Hi All
    Method;
Name:	IMG_0825 - Copy.JPG
ID:	22263 Click image for larger version.
Name:	IMG_0826 - Copy.JPG
ID:	22264 Click image for larger version.
Name:	IMG_0827 - Copy.JPG
ID:	22265 Click image for larger version.
Name:	IMG_0828 - Copy.JPG
ID:	22266 Click image for larger version.
Name:	IMG_0850 - Copy.JPG
ID:	22267 Click image for larger version.
    The Home Engineer
    What's the gas nozzle you are using for heating? and what type of gas are you using
  11. The Following User Says Thank You to swedishchopper For This Useful Post:
  12. #7
    Berkshire UK
    Hi
    MAPP gas on a T2000 torch that plumbers use.
    The Home Engineer
  13. #8
    Dec 2015
    Smile
    Hi
    The Home Engineer
    Okey ,Thank you
  14. #9
    Dec 2015
    Reading, Berks, UK
    Philip Davies's Tools
    Do you weld the notch after bending?
  15. #10
    Berkshire UK
    Hi Philip
    It is up to you if you weld or not I have never welded the notch up on my projects but I guess it all depends on application and how deep the notch is cut. If the piece reqiures a weld I can't see any harm in filling the notch.
    Hope this helps
    The Home Engineer
