Results 1 to 7 of 7
Thread: Micro drill press
    Supporting Member crazypj's Avatar
    Nov 2014
    Central Florida
    crazypj's Tools
    Micro drill press
    Saw an Instructable about using a camera macro focus mount to make PCB drilling feed.
    I don't 'do' PCB (printed circuit board) but, I do recondition CV carburettors from late 60's through mid 70's for Honda 250,350,360, 450 DOHC (had a hand in several of the 360's in bike build section)
    Made this to make new emulsion tubes.
    Almost all from scrap bit's and pieces although I had to buy the Dremel clone and the 90 degree welded aluminium (I still haven't learned to weld aluminium ) It's counter weighted rather than spring tension, gives more consistent feel when driling0.50mm holes through 8mm dia brass. melted down some old lead wheel weights to make counterweight sliding inside column. 'Table' was scrap from motorcycle crate
    Used an old toothbrush handle as the operating handle
    Attached Thumbnails Attached Thumbnails Micro drill press-almost-finished-almost-finished-2.jpg   Micro drill press-last-part-2.jpg
  2. The Following 3 Users Say Thank You to crazypj For This Useful Post:
    hippywarrior2 (Jun 11, 2016), kbalch (Nov 24, 2014), Paul Jones (Nov 26, 2014)
    Very nice! I take it you can't easily find emulsion tubes for CV-type carbs anymore? I'm more familiar with Webers and Mikunis.
    Jul 2014
    San DIEGO, California
    Captainleeward's Tools
    Nice build crazypj :O) Always good to have a good counter weight around.
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks crazypj! I've added your Micro Drill Press to our Drilling and Drill Presses category, as well as to your builder page: crazypj's Homemade Tools. Your receipt:
    Feb 2013
    South of Brazil.
    Hotz's Tools
    cool ... thanks for sharing.
    Sorry my mistakes in english.
    Simple and cheap. Well done crazypj.
    Al
  8. #7
    Supporting Member Vernon's Avatar
    Nov 2014
    Ocala, Florida
    Vernon's Tools
    Pretty need idea I could see a use other than a small drill would be nice for polishing small parts with a small blending wheel.
