Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 28
Thread: Mill conversion. Home made "Marvin" attachment
    Feb 2014
    glens5's Tools
    Home made "Marvin" attachment horizontal to vertical mill conversion.
    1" spindle with MT2 taper.
    Attached Thumbnails Attached Thumbnails Mill conversion. Home made "Marvin" attachment-p1070849.jpg   Mill conversion. Home made "Marvin" attachment-p1070804.jpg   Mill conversion. Home made "Marvin" attachment-p1070807.jpg   Mill conversion. Home made "Marvin" attachment-p1070852.jpg
  2. The Following 20 Users Say Thank You to glens5 For This Useful Post:
    Al8236 (Jun 4, 2020), bigtrev8xl (Mar 2, 2022), Crusty (Jun 2, 2020), DIYSwede (Jun 4, 2020), Drew1966 (Jun 3, 2020), EnginePaul (Jun 4, 2020), JDrouin (Jun 5, 2020), Jon (Jun 3, 2020), KustomsbyKent (Feb 20, 2024), Lee Bell (Jun 3, 2020), marksbug (Apr 8, 2024), metric_taper (Mar 1, 2022), mr mikey (Apr 8, 2024), mwmkravchenko (Jun 3, 2020), NortonDommi (Jun 3, 2020), olderdan (Jun 4, 2020), Paul Jones (Jun 5, 2020), Scotty12 (Jun 3, 2020), threesixesinarow (Jun 3, 2020), Toolmaker51 (Jun 3, 2020)
    Thanks glens5! We've added your Horizontal Mill Vertical Conversion to our Milling category,
    as well as to your builder page: glens5's Homemade Tools. Your receipt:
    Perth Ontario Canada
    Pretty slick. How well does it work?
    Supporting Member Drew1966's Avatar
    Oct 2016
    Elegant. Simple. Good job of doing ones best to battle Murphy.
    Jul 2014
    North Island, New Zealand.
    NortonDommi's Tools
    Very nice. I'm thinking that it is super smooth in use?
    Countless little horizontal mills went to scrap because potential buyers couldn't visualize this.
    Driving from the machine spindle infinitely better than placing that weight atop the fabricated spindle housing. And, still have ready use of the horizontal spindle. You say the bore is #2 Morse Taper; appears those are drawbar [not drift] holders?
  8. #7
    Feb 2014
    glens5's Tools
    Takes a few minutes to set up and align but other than that it seems to work just fine.
    I haven't checked for run out yet but if there is any I'm sure it'll be from the Banggood collets and holder.
  9. The Following User Says Thank You to glens5 For This Useful Post:
  10. #8
    Feb 2014
    glens5's Tools
    The over arm support is 2 1/2" for the for the horizontal spindle support so I turned the vertical attachment from 3" cold rolled steel.
    The bearings are tapered roller bearings, L44643. I turned an extra fine thread on the top of the spindle for adjusting the end play and run out to zero with a special machined castle nut with a round collar that projects through the top seal.
    I wasn't able to turn the bearing cup seats with the two sections welded together and was concerned about the weld pulling but with the wall of the housing close to 1" thick there didn't appear to be any distortion. Peening the short alternate welds may have helped too.
    Interference fits for the spindle bearings as well as the bearings in the idler pulleys.
    MT2 taper with a draw bar. MT3 would have been preferred but would have been too large.
    Attached Thumbnails Attached Thumbnails Mill conversion. Home made "Marvin" attachment-spindle.jpg
  11. The Following 4 Users Say Thank You to glens5 For This Useful Post:
    KustomsbyKent (Feb 20, 2024), olderdan (Jun 4, 2020), threesixesinarow (Jun 5, 2020), Toolmaker51 (Jun 4, 2020)
  12. #9
    Given my name, I have a vested interest in this question...
    Why is it called a "Marvin" attachment ?
    Home Shop Freeware
  13. The Following User Says Thank You to mklotz For This Useful Post:
  14. #10
    Feb 2014
    glens5's Tools
    Certainly not an original idea on my part but it looked like a good idea for converting to vertical.
    Attached Thumbnails Attached Thumbnails Mill conversion. Home made "Marvin" attachment-img24.jpg
  15. The Following 2 Users Say Thank You to glens5 For This Useful Post:
    Jon (Jun 4, 2020), marksbug (Apr 8, 2024)
