Results 1 to 10 of 17
Thread: Milling and CNC Machine Hold Down Clamps
    jjr2001's Tools
    I needed a few good clamps. Saw this type in several places including LMS and I think KBC as well as MSC.
    They don't require packing and can be used with the pallets or T-Slots. Mine are designed for 1/4" bolts.
    I use cap screws for my pallets so I stuck with them for these clamps.
    Normally riveted but I had these brass screws and nuts in the shop so I thought that I could use them
    and have the ability to change out the spacers for other types like brass or steel depending on the job.
    The aluminum ones may have a flat face cut on them if desired. Aluminum sides were all cut on my CNC machine
    after I made the new router mount. The new mount is a total success and makes the machine more rigid than with
    the maple one that broke. The spacers were made on the lathe. The steel cross bolt was made using the mill and the lathe.
    Porter Cable Router Mount thread:
    http://www.homemadetools.net/forum/c...le-mount-66003
    So here they are..Kinda look like little race cars!
    Cheers, JR
    Attached Thumbnails Attached Thumbnails Milling and CNC Machine Hold Down Clamps-img_1551b-copy.jpg   Milling and CNC Machine Hold Down Clamps-img_1552b-copy.jpg   Milling and CNC Machine Hold Down Clamps-img_1553b-copy.jpg   Milling and CNC Machine Hold Down Clamps-img_1554b-copy.jpg
  2. The Following 18 Users Say Thank You to jjr2001 For This Useful Post:
    emu roo (Jun 28, 2024), Frank S (Jan 29, 2018), freddo4 (Mar 24, 2020), high-side (Aug 1, 2019), HobieDave (Mar 25, 2020), Jon (Dec 5, 2019), NickP (Jan 31, 2018), NortonDommi (Jun 22, 2018), Okapi (Jun 8, 2018), philipUsesWood&Brass (Jun 7, 2018), PJs (Jan 31, 2018), Ralphxyz (Aug 22, 2024), Scotsman Hosie (Feb 21, 2018), Seedtick (Jan 30, 2018), Sleykin (Mar 24, 2020), Syko Triker (Feb 7, 2018), that_other_guy (Aug 18, 2024), will52100 (Jan 30, 2018)
    Berkshire UK
    thehomeengineer's Tools
    Hi very nice. makes life so much easier when you have the correct tooling for the job. I really like the design and I know you said they don’t need packing but I guess if needed you could increase the height, you just place a block under the toe of the clamp and use a long piece of studding. Neat design and nicely made.
    thank you for sharing
    The Home Engineer
  4. The Following 4 Users Say Thank You to thehomeengineer For This Useful Post:
    greyhoundollie (Mar 25, 2020), jjr2001 (Jan 29, 2018), Paul Jones (Jan 29, 2018), Scotsman Hosie (Feb 21, 2018)
    They look a lot like roller rockers, you could actually use discarded roller rockers from engines. If you can score a set of 1.6 to 1 ratio from a big block chevy race engine all the better but the 1.5 to 1's are just fine
  6. The Following 8 Users Say Thank You to Frank S For This Useful Post:
    freddo4 (Mar 24, 2020), greyhoundollie (Mar 25, 2020), jjr2001 (Jan 29, 2018), NortonDommi (Jun 22, 2018), PJs (Jan 31, 2018), rdarrylb (Mar 24, 2020), Scotsman Hosie (Feb 21, 2018), Sleykin (Mar 24, 2020)
    jjr2001's Tools
    Thank you both. Homeengineer, yep sure can use packing if you need it for larger pieces. These clamps will
    work in many situations.
    Frank, never thought of that but I think you have something there. I like the idea of re using existing parts especially when
    you can use them for tools.
    Cheers, JR
  8. The Following User Says Thank You to jjr2001 For This Useful Post:
    Thanks jjr2001! We've added your Hold Down Clamps to our Clamps category,
  10. The Following User Says Thank You to DIYer For This Useful Post:
  11. #6
    This style of clamp, minimizing the need for packing, is great for quick clamping. My approach to making them is a bit simpler. Slices of pipe are bisected and a slot cut with an endmill. Add a piece of studding and, voila, clamps.
  12. The Following 11 Users Say Thank You to mklotz For This Useful Post:
    Frank S (Jan 30, 2018), freddo4 (Mar 24, 2020), high-side (Mar 24, 2020), jjr2001 (Jan 30, 2018), NickP (Jan 31, 2018), NortonDommi (Jun 22, 2018), rdarrylb (Mar 24, 2020), Scotsman Hosie (Feb 21, 2018), Sleykin (Mar 24, 2020), Syko Triker (Feb 7, 2018), will52100 (Jan 30, 2018)
  13. #7
    jjr2001's Tools
    Nice looking clamps Marv and easy to make in various sizes.
    Thanks for posting.
    Cheers, JR
  14. #8
    Supporting Member scrdmgl's Avatar
    Oct 2013
    Toronto, Ontario, Canada
    scrdmgl's Tools
    Hi JR: I wonder if you tried to use your clamps for a dual purpose, as regular clamps applying downward pressure on the part being held and also as an edge or low clearance clamp for thin work pieces. Given the pivoting hold down bolt, if set against the side of a plate it would apply downward pressure on the piece to be machined. The bearings at the end allow easy rolling of the clamp while tightening, it should work. I've seen similarly designed clamps used that way.
    Regards
    Jorge
  15. The Following User Says Thank You to scrdmgl For This Useful Post:
  16. #9
    jjr2001's Tools
    Thanks for the idea Jorge, I have not tried that since my bolts are in a vertical plane when used on the
    pallet or with T-nuts on the mill. I have been using my own mite-bite type clamps for the edges.
    My clamping on the CNC finds the bite type clamps great for the edges. I then use some rather block
    style clamps for the opposite sides where the bite clamps can press on. Then the new hold downs on top.
    Works to a treat as they say.
    Cheers, JR
  17. #10
    Oct 2012
    Jr
    Very nice and looks good.
    Marv
    Very nice and simple for someone like me.
    Nelson
  18. The Following User Says Thank You to ncollar For This Useful Post:
