Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
Thread: Milling machine power feed
    Jun 2018
    Stevohdee's Tools
    hey guys
    Developed RSI after turning the x axis for hours on end, hence had to make power feed device. OMG... never gunna do it the old way ever again!!
    Here's what I came up with...
    cheers stevoh
  2. The Following 19 Users Say Thank You to Stevohdee For This Useful Post:
    almarghi (Aug 22, 2018), bruce.desertrat (Aug 22, 2018), DaleG (Aug 22, 2018), emu roo (Jun 30, 2025), high-side (Aug 23, 2018), Home-PC (Sep 2, 2021), Jon (Aug 22, 2018), Ken Koch (Aug 23, 2018), Miloslav (Aug 22, 2018), MountainMan (Aug 23, 2018), mwmkravchenko (Dec 14, 2018), NickP (Dec 14, 2018), PJs (Aug 22, 2018), rossbotics (Aug 23, 2018), Seedtick (Aug 22, 2018), Tonyg (Sep 16, 2020), trigger (Sep 15, 2020), Tule (Aug 25, 2018), UncleBob (Aug 25, 2018)
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Bravo, Nice and clean Stevoh! Looks like you already got an award for it on the inside of the sheet metal. Did you fabricate the controller board? I see the screw coupling and flex coupler but curious how you did it. Been a few conversation here about how it gets done and would enjoy your take on doing it.
    Thanks, Great share!
    PJ
    Mark Twain
  4. The Following User Says Thank You to PJs For This Useful Post:
    Jun 2018
    Stevohdee's Tools
    Thanks PJ,
    I've got an electronics engineer friend whos amazing, I just tell him what I need and he makes it. He found the motor and electronics and I designed the box around the bits and installed them. The box is made from spare award A4 size plates I used to engrave, had so many @ one stage just threw them out. Here's a few pics of coupling.
    This pic shows the material I found on the side of road... yaaayy, freebie!!
    cheers
  6. The Following 4 Users Say Thank You to Stevohdee For This Useful Post:
    emu roo (Jun 30, 2025), Home-PC (Sep 2, 2021), PJs (Aug 23, 2018), Tule (Aug 25, 2018)
    Do you have the ability to disengage it for those times when you will need to use the manual wheel?
    Jun 2018
    Stevohdee's Tools
    Hey frank, no disengage system, turning the wheel by hand just turns the motor with it no problem
  10. The Following User Says Thank You to Stevohdee For This Useful Post:
  11. #6
    I was just wondering because I used to have a Bridgeport with power feed I had to dis engage the feed to use the hand wheel
    Edit, is the electronics and the motor capable of upgrading to NC or CNC later on if you wanted to do so?
  13. #7
    Jun 2018
    Stevohdee's Tools
    I guess different kind of motors or gearing
  14. The Following User Says Thank You to Stevohdee For This Useful Post:
  15. #8
    Quote Originally Posted by Stevohdee View Post
    The Bridge port had a 96v DC motor with right angle drive something like 12 wires came out of it
  16. The Following User Says Thank You to Frank S For This Useful Post:
  17. #9
    Dec 2013
    Florida
    rossbotics's Tools
    Good work and nice job
    back when I started my apprentice 44 years ago they wouldn't let us use power feed on the mill, they wanted us to feel the cutter cutting and get the feel of how fast you can turn the crank without destroying the end mill, got tired of cranking the mill handle real quick.
    Nice Job
    Doug
    Comments are always welcome
    Doug
  18. The Following User Says Thank You to rossbotics For This Useful Post:
    PJs (Aug 23, 2018)
  19. #10
    Sep 2012
    Hinchinbrook QLD
    Nice work Steve. Are you in Australia?
    Phil
