Results 1 to 6 of 6
Thread: Miniature lantern tool post
    Ok, this is a bit of a joke but it took as long to make as if it were a practical size. It's a functional lantern tool post complete with rocker and bit ground with the proper angles to cut threads.
    It was made to fit on my working dollhouse scale (1/12) metal lathe, made from a casting set obtained from PM Research. This picture shows it in place on the cross slide.
  2. The Following 8 Users Say Thank You to mklotz For This Useful Post:
    baja (Jul 26, 2019), Christophe Mineau (Jan 19, 2016), gunsgt1863 (Nov 17, 2017), jjr2001 (Dec 22, 2017), kbalch (Jan 17, 2016), old_toolmaker (Sep 9, 2022), Paul Jones (Jan 19, 2016), PJs (Jan 19, 2016)
    Thanks mklotz! We've added your Miniature Lantern Tool Post to our Machining category, as well as to your builder page: mklotz's Homemade Tools. Your receipt:
    Supporting Member Al8236's Avatar
    Dec 2014
    Kendall Washington
    Al8236's Tools
    Looks good, that's working in miniature! Now are you going to attempt some itty bitty Armstrong bit holders?
    From the time you're born till' you ride in a hearse, there's nothing so bad it couldn't be worse!
    Quote Originally Posted by Al8236 View Post
    The lathe prototype is early Victorian so I think it predates the Armstrong holder. However, I did build a working four jaw independent chuck for it...
    The chuck is 1" in diameter. Setscrews are used to move the jaws, hence the somewhat inaccurate hexagonal chuck wrench.
  6. The Following 2 Users Say Thank You to mklotz For This Useful Post:
    baja (Jul 26, 2019), PJs (Jan 19, 2016)
    May 2014
    Del Mar, California
    Paul Jones's Tools
    Marv,
    Really nice miniature machining work on the tools. What is the thread size of the clamping screw on the lantern tool post? Looks extremely small. Thanks for posting,
    Paul
    Marv,
    Paul
    The screw is a 0-80 SHCS - not easy to find those, or the wrenches to fit them.
    I can remember when I started building miniatures that a 2-56 thread looked impossibly small; I'd never be able to tap that without breaking the tap. But, the longer you work in miniatures, the bigger this stuff seems to become. With the proper (homemade) tooling, 1-72 and 0-80 are perfectly doable. To date, the smallest I've done is 00-90. I have a tap for 000-120 but, thankfully, a situation requiring that has never arisen.
    Download plans for tool posts.
  9. The Following 3 Users Say Thank You to mklotz For This Useful Post:
    baja (Jul 26, 2019), PJs (Jan 19, 2016), Toolmaker51 (Nov 16, 2017)
