Results 1 to 10 of 14
Thread: Model Engine Review - Enjomor Whippet
    Supporting Member editor@glue-it.com's Avatar
    Apr 2017
    UK
    editor@glue-it.com's Tools
    This is a model engine that I've been sent to have a look at, review and have a play with. First of all I'm unpacking and having a look at it:
    Apr 2017
    UK
    and a bit more of a look around the engine, exhaust, carburetor and coolant connections
    Unpacking the Enjomor Whippet
  3. #3
  4. #4
    Apr 2017
    UK
    I needed a cooling water tank, trouble was the larger tins had the right look and the smaller tins were the right diameter....
  5. #5
    Apr 2017
    UK
    Someone commented that this doesn't fit the aesthetics of the normal models I make, I think he has a point....
  6. #6
    Apr 2017
    UK
    Finally running the engine, initially on glow fuel.
    Credit to the design of E.T. Westbury for how easy this is to start and how well the Whippet runs.
  7. #7
    Apr 2017
    UK
    I've been making wheels to create a trolley for the Whippet
    Made from 1/4" thick mild steel. Hopefully they look like an old cast wheel that you might find on a stationary engine trolley - thoughts?
  8. #8
    Apr 2017
    UK
    I've just briefly written up the process I followed for making these wheels, the most important step was making a mandrel so that I could easily and repeatable mount each wheel to the lathe and then the milling machine.
  9. #9
    Apr 2017
    UK
    The final design and installation of the Enjomor Whippet engine on a trolley
    What do you think?
    I will now run it as installed on the trolley and post the video.
  10. #10
    Quote Originally Posted by editor@glue-it.com View Post
    The texture of casting might be imparted by etching or shot blasting. Blast might edge out for appearance, it'll blend every tool mark evenly. There might be a way to texture paint or add a 'contaminant' instead. But they are beautiful raw.
    When I needed a super finish on narrow surfaces, the trick was stoning one flute off a two flute end mill, making it a fly cutter, but makes clean corners tedious.
  11. The Following User Says Thank You to Toolmaker51 For This Useful Post:
    editor@glue-it.com (Jun 3, 2022)
