Results 1 to 10 of 12
Thread: Motor Speed Controller Voltage Regulator Dimmer
    Jun 2019
    Michael Paley's Tools
  2. The Following 9 Users Say Thank You to Michael Paley For This Useful Post:
    Altair (Oct 13, 2019), dietmar g (Dec 4, 2021), fmerenda (Oct 21, 2019), Home-PC (Oct 14, 2019), Jon (Oct 17, 2019), Paul Jones (Nov 5, 2019), Redwoods (Oct 21, 2019), Slim-123 (Oct 14, 2019), Texf1 (Oct 21, 2019)
    Stockholm, Sweden...
    DIYSwede's Tools
    Thanks for sharing!
    Do you power this from a 16 amp outlet?
    Then you might profit by using at least AWG 16 wiring, an output fuse/ GFI and perhaps some vents in the box?
    2 cents
    Johan
  4. The Following User Says Thank You to DIYSwede For This Useful Post:
    emu roo (Nov 22, 2025)
    Thanks Michael Paley! We've added your Power Tool Speed Controller to our Electrical category,
    as well as to your builder page: Michael Paley's Homemade Tools. Your receipt:
  6. The Following User Says Thank You to Altair For This Useful Post:
    Supporting Member Slim-123's Avatar
    Mar 2019
    Россия Краснода&
    Хорошее приобретение Майкл. Я тоже приобрёл такой регулятор. Но у меня есть один совет. При использовании регулятора более двух киловатт он сильно нагревается и ему нужно охлаждение. По этому сделай короб более доступный для охлаждения..
  8. The Following User Says Thank You to Slim-123 For This Useful Post:
    Supporting Member pfredX1's Avatar
    Sep 2016
    Delaware
    pfredX1's Tools
    heh I should post my phase fired AC circuits. I actually make the electronics for these things. They're simple devices. The only trick is using the right AT leg on the triac for the input current. I think it has something do to with the topography of the device? All I really know is backwards they don't work. Alternating current has more polarity than most realize it does. More than I gave it credit for before messing with it. Autotransformers don't work hooked up backwards either. That's where I first discovered the phenomena for myself. Live and neutral are different beasts. But here's a schematic for the simplest dimmer http://i.imgur.com/GE3ZXqP.png and you tie the neutrals and run the live through the circuit. Here's what that looks like physically https://i.imgur.com/M7WENhG.jpg Not much to it.
  10. The Following User Says Thank You to pfredX1 For This Useful Post:
  11. #6
    Oct 2019
    Thanks!
    Quote Originally Posted by Michael Paley View Post
    thanks for the video. I’m definitely going to build one!
  12. #7
    Oct 2019
    There's so crazy, i just made this exact same thing with the same piece last night! No joke. It's so handy, this is like the 4th one I've made because everyone that sees it wants one!
  13. The Following User Says Thank You to fmerenda For This Useful Post:
  14. #8
    Mar 2019
    What's the difference between this and the router speed control you can get at harbor freight or many other places? Is this one better for the tools or is it basically the same thing?
  15. The Following User Says Thank You to Chadboye For This Useful Post:
  16. #9
    Sep 2016
    Delaware
    pfredX1's Tools
    Quote Originally Posted by Chadboye View Post
    I never looked inside the Harbor Freight speed controller. So I can't say for sure what's inside it. I would not say mine is any better for the tool. It may be more rugged than what you can buy commercially. I haven't looked in the HF speed controller but I've looked in others. The part that does the work in all of them (the TRIAC) tends to be marginal. Now maybe HF put a really good part in theirs? But if they did they'd be the first. Which is why I just made one. Because everything I have seen has all been junk. But semiconductor technology has come a ways. The decent TRIAC I did use did not cost me much to buy. Like 25 cents. You'd think the manufacturer would splurge if the part was that critical. So far I haven't seen it myself.
  17. The Following 2 Users Say Thank You to pfredX1 For This Useful Post:
    Chadboye (Dec 1, 2021), emu roo (Nov 22, 2025)
  18. #10
    Aug 2012
    Australia
    desbromilow's Tools
    I use those modules, with a 30A full wave bridge rectifier, to make up speed controllers for 180VDC treadmill motors. They work well, and I have yet to see a need to add any smoothing capacitors on the output, but it is still an option.
  19. The Following User Says Thank You to desbromilow For This Useful Post:
