Results 1 to 5 of 5
Thread: motorcycle lift table plans and help and suggestions
    Jul 2015
    Request help in plans for making in expensive motorcycle lift table due to bad knees and back
  2. #2
    Dec 2014
    Bike lift
    I've been considering the same project. My main concerns are bike stability and cost. I also have very little space for storage when not in use. My first thought is to ride onto a lowered platform and put front wheel into a chocking device. I'm older and want to work from a stool so I do t need to go up 30" like commercial lifts. I can lift one end at a time then set a jack stand device. Some wood is OK but pivots, bearings and locks need to be metal I think.I've looked at a lot of designs online. I always start my projects with lists of desires, concerns, limitations, ideas I've seen, and items I want to avoid. Keep a log or tablet and add things as they come up. Make sketches, quantify dimensions, loads, and geometry parameters. Get some pricing on materials you think you might use. I frequent salvage yards, yard sales and street side discard piles. Repurposing stuff keeps some costs down but can increase other costs or complicate design.
    Good luck,
    Gene
  3. #3
    I looked at one, then built it out of angle iron angle and used a inexpensive 12v winch to lift and lower.
  4. #4
    ecm_this's Avatar
    Feb 2014
    ecm_this's Tools
    I used these, and modified it to use a HF air over hydraulic cylinder. Works like a champ.
    ekoinstal.com/skutery/Inne%2520AFAB_Motorcycle_Table_Lift_Plans
    Add the w's where they belong.
  5. #5
