Results 1 to 10 of 11
Thread: Motorized Drill Press Table Lift
    Mar 2014
    Houston, TX
    shopstorm's Tools
    Drill press table crank problems .... I know I'm not the only one!
    My DP table accessories are heavy.
    My custom woodworking table impedes the rotation of the crank handle.... knuckle buster!
    I routinely work large/long items, so my table lift gives me a workout.
    Given all of the advancements the DP has seen, variable speed, rapid speed change, keyless chuck, laser site, etc... The hand crank is laboriously outdated, especially on higher end machines.
    I removed my crank handle exposing the rack and pinion drive shaft and found a way to mount a motor.
    Initial specs and estimates led to a lot of trial and error, but I found a great combo of hardware that gets the job done based on a $5 DC power tool motor.
    Parts include:
    Aluminum L bracket for mount
    Small high RPM DC motor with cooling fan
    3 stage gear reduction
    Drive shaft coupler
    Mechanical and logical motor controls for speed direction
    AC to DC power converter/supply
    Inline fuse protection
    Mounting hardware
    Cable management
    Motor enclosure
    Install requires: drill, metal bits, taps, screw driver, allen wrench
    Take a look at the video .... Very straight forward operation. Easy up, easy down!
    I've also added some photos.
ID:	2788   Click image for larger version.
ID:	2789   Click image for larger version.
ID:	2785   Click image for larger version.
ID:	2786   Click image for larger version.
  2. The Following 8 Users Say Thank You to shopstorm For This Useful Post:
    Altair (Jan 18, 2015), bobs409 (Apr 17, 2020), emu roo (Jan 24, 2025), kbalch (Jan 16, 2015), nimedic (Jul 28, 2020), Paul Jones (Jan 15, 2015), Saltfever (Aug 25, 2020), Tuomas (Apr 17, 2020)
