Results 1 to 10 of 16
Thread: Mount for the hydraulic jack.. Turning it upside down.
    Jyväskylä Finland
    Tuomas's Tools
    Wanted to add bigger jack to my press.
    To get most of the pressure to the small area, i decided to turn the jack upside down.
    This way i can mount hole punching and stamping dies directly to the cylinder of the jack.
    In use:
    Attachment 23111
    Stored:
    Attachment 23110
    Takes about 10 seconds to assemble / disassemble.
    Springs are surplus from trampoline. Bigger holes drilled with a variable wood cutter, with diy hss blade.
    Used cheap 8 ton jack that was sealed with welds.
    Actually this should work with "any" jack, without need to open it.
    Here is the video:
    More info:
    Picture shows how springs goes between the rods that hold the jack
    Attachment 23112
    Jack mount is locked on its place with two M8 screws. Lid in front is weld to the mount...
    Attachment 23113
    Latch on the back is bolted to the press frame..
    Attachment 23115
    This is the reason why i welded similar plates to the bottom and upper bars of the frame..
    Attachment 23116
    I can use same dies with both jacks.. when i need to bend thicker materials i use bigger jack..
    With thinner ( <5mm ) i use smaller one, wich is more accurate and faster to use.
    Attachment 23117
    I used surplus cutting fluid container as a oil container,
    for mounting it to the press, i used clamp that's originally intented to connect flashlight to the welding mask.
    Attachment 23118
    Hose clamps..
    Attachment 23119
    And why i originally wanted to add this jack to my press.. i had this idea in firts place when i made the original frame, but no i needed it. So, i made it.
    For stamping sheet metals. These are going to be reflectors for small leds. I got idea from Tony Foale, i decided to place dozen small led spotlights to my shop where i need more light.
    Attachment 23120
    Edit:
    New container:
    Fitting. Didn't find suitable, so i made it from bigger one, cut the end out and welded piece of 6mm ( hose is with 6mm inner dia ) thick pipe to it.
    Connections..
    Cap is made from a bolt. I filed groove to it, it allows container to breathe.
    Open..
    Closed.. When stored, so it doesn't leak if it falls.
    Easy to fill..
    Ready.
    I used this hose in that first version. Now i changed it to appropriate one...
    But at that time, i had any hose and stores we're closed. So, i improvised.
    I peeled it from electric cable. It worked nicely that time i used it, but i decided to change it before it breaks.
  2. The Following 19 Users Say Thank You to Tuomas For This Useful Post:
    baja (Sep 2, 2020), bigtrev8xl (Jul 25, 2018), blkadder (Jun 12, 2023), DIYer (Apr 7, 2018), Dollar Bill (Jun 12, 2023), emu roo (Nov 11, 2024), Frank S (Jul 23, 2018), LMMasterMariner (Apr 7, 2018), MountainMan (Aug 6, 2018), mwmkravchenko (Apr 6, 2018), NortonDommi (Jul 27, 2018), Priemsy (Apr 6, 2018), rossbotics (Apr 18, 2018), Seedtick (Apr 6, 2018), Steved53 (May 9, 2018), Tonyg (Sep 2, 2020), Toolmaker51 (Aug 5, 2018), Tule (Sep 14, 2023), wolfpaak (Sep 9, 2023)
    Supporting Member Priemsy's Avatar
    I tried using one on its side but it wouldn't work
    Jyväskylä Finland
    Tuomas's Tools
    Quote Originally Posted by Priemsy View Post
    All air needs to be removed inside the jack.
    Thanks Tuomas! We've added your Inverted Jack Mounting to our Jacks and Lifts category,
    Ahhhh. That must have been the problem. Thank you.
    Jyväskylä Finland
    Tuomas's Tools
    New oil container. Made from stainless steel.
    Mount for the hydraulic jack.. Turning it upside down.-fb_img_1523889446431.jpg
    Mount for the hydraulic jack.. Turning it upside down.-fb_img_1523889455593.jpg
  8. The Following User Says Thank You to Tuomas For This Useful Post:
    Priemsy (Apr 16, 2018)
  9. #7
    Jyväskylä Finland
    Tuomas's Tools
    Couple more pictures
    Connections..
    Open..
    Easy to fill..
    Ready.
  10. #8
    Jyväskylä Finland
    Tuomas's Tools
    20 ton press. Jack is inverted same way as shown on the video above.
    This time oil tank is integrated to press frame.
    Mount for the hydraulic jack.. Turning it upside down.-fb_img_1532402677283.jpg
    Mount for the hydraulic jack.. Turning it upside down.-fb_img_1532402689676.jpg
    12mm plate and 160 x 60mm u-channel with 12mm wall.
    Should handle bigger jacks too.
  11. The Following 9 Users Say Thank You to Tuomas For This Useful Post:
    bigtrev8xl (Jul 25, 2018), blkadder (Jun 12, 2023), Frank S (Jul 23, 2018), NortonDommi (Jul 27, 2018), PJs (Jul 25, 2018), rlm98253 (Jul 24, 2018), Seedtick (Jul 29, 2018), Toolmaker51 (Jul 25, 2018), volodar (Jul 24, 2018)
  12. #9
    charles scozzari's Avatar
    May 2016
    Staten Island NY
    charles scozzari's Tools
    Nice design, beautiful welding. Thanks for posting.
  13. The Following User Says Thank You to charles scozzari For This Useful Post:
    Tuomas (Jul 24, 2018)
  14. #10
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Nice to see the incorporated tank and more versatility in Jacks is a bonus! Thanks Tuomas!
    PJ
    Mark Twain
  15. The Following User Says Thank You to PJs For This Useful Post:
    Tuomas (Aug 5, 2018)
