Results 1 to 6 of 6
Thread: Nut tapping machine - GIF
    Nut tapping machine.
    Tapping machine - video
    2-inch power tapping - GIF
    Tapmatic - video
    Magnetic tapping fixture - video
    Large diameter tap - photo
  2. The Following 8 Users Say Thank You to Altair For This Useful Post:
    albertq (Apr 1, 2024), davesrepair (Apr 1, 2024), durrelltn (Jan 29, 2022), emu roo (Jun 11, 2026), mwmkravchenko (Nov 4, 2021), nova_robotics (Nov 6, 2021), Ralphxyz (Nov 6, 2021), that_other_guy (Nov 26, 2021)
    Jun 2012
    Harvey Melvin Richards's Tools
    Well that’s just nuts.
  4. The Following 2 Users Say Thank You to Harvey Melvin Richards For This Useful Post:
    davesrepair (Apr 1, 2024), emu roo (Jun 11, 2026)
    In re: to post 1, nut tapping machine. An expedient fully hands off process, though not I think common as equipment using bent shank taps.
    https://patents.google.com/patent/US5199927A/en
    Most tapping heads run spindle speed to cut but 1.5 or 2x in reverse to reduce cycle time. That's not visible in GIF presented.
  6. The Following User Says Thank You to Toolmaker51 For This Useful Post:
    Dec 2016
    Ralphxyz's Tools
    What is that tap made of? There isn't any coolant or lube and it keeps on cranking them out.
    Ralph
  8. The Following User Says Thank You to Ralphxyz For This Useful Post:
    Ralph
    Taps are HSS, cobalt, even carbide.
    And, with out losing my text to go look, might be thread forming, not conventional tapping at all. There are no chips, with significant increase in thread quality.
    Likely they aren't 10.9 or Grade 8 equivalent fasteners, 2 or 5 are just decent steel, so toughness isn't an issue.
    There is enough cycle time and reasonable RPM to keep tap at same temperature, but might have mist or air to push chips as well. The locators would need a bit of air to keep jaws clean and locate part dependably. We don't realize how much excess WE visibly use of that!
    The TiN type coatings can take a zillion cycles, but really help initially breaking a cutter in so it will last.
    https://www.regalcuttingtools.com/pr...2%80%93-metric
  10. The Following User Says Thank You to Toolmaker51 For This Useful Post:
  11. #6
    Mar 2020
    Ralph
    Must be solid carbide. Carbide can be used with or without coolant. Hot carbide are subject to thermal cracking when hit by small amount of unevenly-applied coolant. Therefore, it's recommended either full-flood coolant or no coolant at all.
