View Poll Results: Vise mounting how-to
Voters
8. You may not vote on this poll
  • Had you done this already?
    5 62.50%
  • If not, did it interest you?
    3 37.50%
  • Are the guidelines clear?
    5 62.50%
Multiple Choice Poll.
Results 1 to 10 of 11
Thread: Obliged to post; Mounting of bench vises.
  1. #4
    piper184's Avatar
    Jul 2016
    piper184's Tools
    My vice is mounted with the stationary jaw a little forward of the bench edge. Pretty sturdy wood bench with bolts all the way through the top. I have not had a reason to make a base plate as it has stood up for nearly 20 years without any loosening. However, I did have to bolt the bench to the wall as sometimes I get a little "rough" with things. Finding open space on the bench is a larger problem than a loose vice.
    I also have an el-cheap-o 4" vice that usually gets c-clamped to my outdoor welding table. Easy to get it out of the weather that way. I could bolt it to the top, but the table is not very heavy duty so it is not used for "rough" work.
  2. The Following User Says Thank You to piper184 For This Useful Post:
    dsmythe (Aug 9, 2016)
