Results 1 to 8 of 8
Thread: Offset Tailstock Center
    Dec 2017
    Cape Coral, FL
    old_toolmaker's Tools
    Offset Tailstock Center Plans for Sale - $5.00
    $5.00 - Click here to buy now via PayPal and download instantly
    30-day money-back guarantee.
    If you purchase these plans and are not 100% satisfied, we'll refund your purchase price.
    These plans include:
    • A 9-page PDF manual.
    • 5 technical drawings.
    • 4 color photographs.
    Feel free to post any questions you may have in this discussion, either before you purchase or during construction. Or, post pictures of your finished offset tailstock center.
  2. The Following 2 Users Say Thank You to old_toolmaker For This Useful Post:
    allenz (Sep 26, 2022), Seedtick (Jan 26, 2018)
    Dec 2017
    Cape Coral, FL
    Setting the tailstock over to cut a long taper between centers can be a process in its own right, but realigning the tailstock to a zero taper condition when finished can test ones patience. I thought there must be a better way to do this.
    So I designed this offset tailstock center to fit the mini lathe #2 Morse taper tailstock socket as an attempt to solve this perennial problem. With this attachment the tailstock need never be offset. The attachment neatly fits into the tailstock barrel and is indicated in to a true horizontal position..The offset is set on the attachment itself and therein lies its utility. Most of the machining can be done on the lathe. In fact all the machining can be done on the lathe with a milling attachment if no milling machine is available. The plan includes detailed drawings and a step by step description to aid in building.
    Dick
  4. The Following 3 Users Say Thank You to old_toolmaker For This Useful Post:
    bobs409 (May 15, 2018), jjr2001 (Sep 7, 2018), philipUsesWood&Brass (Jul 6, 2018)
    jjr2001's Tools
    Shop Made Tail Stock Center for Mini lathe or Sherline or Unimat from plans.
    Nice set of plans and instructions for the offset tail stock center. One of my future projects will be an 8 to 12 inch long cannon.
    This center is just the tool to use for that long taper.
    Build is straight forward and easy to make on home shop equipment.
    Here is the picture of the completed center.
    Thanks for posting the plans.
    Cheers, JR
    Attached Thumbnails Attached Thumbnails Offset Tailstock Center-img_2065.jpg   Offset Tailstock Center-img_2066.jpg
  6. The Following 2 Users Say Thank You to jjr2001 For This Useful Post:
    old_toolmaker (Sep 29, 2018), Scotty1 (Nov 20, 2018)
    Dec 2017
    Cape Coral, FL
    jjr2001,
    That is some very nice work! I am sure it will fulfill its intended purpose on the canon barrel. Thanks for posting pictures of your build!
    Dick
    Links to some of my plans:
  8. The Following User Says Thank You to old_toolmaker For This Useful Post:
    jjr2001 (Sep 29, 2018)
    jjr2001's Tools
    Thanks Dick, I enjoyed the build and the plans were right on!
    I have the plans for the small QC tool post and need to make that for my little Sherline.
    Thanks again, JR
  10. #6
    Dec 2017
    Cape Coral, FL
    jjr2001,
    I know you will like the small QC Tool Post. I don't know the centerline distance from cross slide to spindle center on the little Sherline lathe, but you can increase the height of the main block to suit your application. I have used this little QC Tool Post on my 7 x 16 lathe with great success.
    Dick
  11. The Following User Says Thank You to old_toolmaker For This Useful Post:
    jjr2001 (Sep 30, 2018)
  12. #7
    jjr2001's Tools
    Yes, I was looking at that. Nice thing about building tools you need is that customization factor.
    I will need to raise the height to match my Sherline. Could do it with a riser block like sherline uses
    for a lot of applications but I think I will just add the height to the post when I build it.
    Thanks again, JR
  13. #8
    Dec 2017
    Cape Coral, FL
    jjr2001,
    That sounds like a good plan.
    Dick
