Results 1 to 8 of 8
Thread: Overhead pneumatic hose connection.
    Jyväskylä Finland
    Tuomas's Tools
    Hi.
    Picture is taken from my workplace, but its made using angle grinder, drill and mig. Doesn't reguire special tools.
    I tought one could find it usefull idea.
    Material is 50mm ( 2" ) x 50mm x 5mm square tubing.
    Plates at the ends are 6mm thick.
    Pressure inside it is 6 bars.
    Moves hoses from the floor. Hose holders are made from mig wire spools ( 15kg ).
  2. The Following 6 Users Say Thank You to Tuomas For This Useful Post:
    bobs409 (Apr 23, 2018), DIYer (Apr 20, 2018), PJs (Apr 19, 2018), Seedtick (Apr 20, 2018), sossol (Apr 19, 2018), Toolmaker51 (Apr 19, 2018)
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Thanks Tuomas nice idea. Having a manifold drop like that in a shop, large or small, is handy. Interesting the square tube is pressurized with 6 bar (~90psi)...More good welding!!
    PJ
    Mark Twain
  4. The Following User Says Thank You to PJs For This Useful Post:
    Tuomas (Apr 20, 2018)
    I never liked air hoses lying on the floor, not a fan of recoiling spools either. But both are the predominate means of supplying air.
    Toumas's overhead extension beats both of those; I will adopt these exactly, with a portable manual spool or two, when I plumb for air.
  6. The Following 2 Users Say Thank You to Toolmaker51 For This Useful Post:
    PJs (Apr 20, 2018), Tuomas (Apr 20, 2018)
    Jul 2016
    I could see a pivoting arm off the end to position a light over work, double use.
    Eric
  8. The Following 2 Users Say Thank You to suther51 For This Useful Post:
    I haven't set up an air supply system for my machine van but I always liked having a hose hanging instead of being om the floor back when I had my old shop I used DOT coiled trailer hoses to supply most of the air to work stations the air brake hoses are very durable and will not kink like the cheapo yellow ones you see so many people use at their work stations plus they will supply enough volume to run a 1/2 inch impact
    I replace quite a few trailer hoses from time to time but keep the ones I feel are still serviceable for my own future use.
    A coiled hose on an articulated overhead arm with a work light would be the way to go I think.
  10. The Following 3 Users Say Thank You to Frank S For This Useful Post:
    PJs (Apr 20, 2018), Toolmaker51 (Apr 20, 2018), Tuomas (Apr 20, 2018)
  11. #6
    Tuomas,
    The extra volume in the tube is like having a small buffer tank near to the tool being used. The larger the tube the greater the benefit.
  12. The Following 4 Users Say Thank You to tonyfoale For This Useful Post:
    DIYer (Apr 20, 2018), PJs (Apr 20, 2018), Toolmaker51 (Apr 20, 2018), Tuomas (Apr 20, 2018)
  13. #7
    Thanks Tuomas! We've added your Overhead Pneumatic Hose Connection to our Air Compressors category,
  14. #8
    Jyväskylä Finland
    Tuomas's Tools
    Tuomas,
    Yep. We use these containers when there's multiple persons working at the same spot.
    When welding you usually don't need to use very big tools. Pneumatic hammer for removing splatters and slag, small grinder and rotary tool. Those doesn't reguire very big airflow
    5 persons can easily use one wall connection when using that extra container. ( more likely they don't use pneumatic tools at the same time, couple are allways welding)
  15. The Following 2 Users Say Thank You to Tuomas For This Useful Post:
