Results 1 to 10 of 21
Thread: Pantogragh style tracing torch project
  1. #8
    A little time today to make some progress on my pattern torch
    I had welded 1/2" thick ends to teh short pipe pieces then chucked them in the lathe and did a minimum clean up on them then with a 5/8 bit in the tail stock I drilled all the way through
    then I used a " drill I drilled all the way through 1 part then on the second part I stopped about 1/8" short of going all the way through the reason for this will be explained latter
    A few items for helping hands to hold the parts square to each other
    the completed arm except for the ends that will eventually hold a drive motor and what ever torch I use
  2. The Following 2 Users Say Thank You to Frank S For This Useful Post:
    emu roo (Apr 22, 2026), Sleykin (Jun 8, 2022)
