Results 1 to 5 of 5
Thread: parallel riser blocks with tramming pins
    In getting ready to mill the edge of an 8ft I beam I needed to raise it enough to clear the hand wheels of the bed and at the same time be able to maintain a reasonable tram while having to shift it along its length.
    I have a couple of 1 1/2" square bars that are key-stock quality in squareness but had been painted. First I cut a couple 7" long pieces removed the paint then cut 2 pieces of 3/4 cold roll round stock and drilled them to 1/2" on the lathe then loosely bolted these to thew mill table
    After placing the I beam on the blocks I trammed it to the table by tapping on it until it was against both pins then tightened the bolts to keep the tramming pins and the riser blocks in place
  2. The Following 5 Users Say Thank You to Frank S For This Useful Post:
    JDrouin (Feb 20, 2022), Jon (Feb 18, 2022), mwmkravchenko (Feb 16, 2022), NortonDommi (Feb 19, 2022), Toolmaker51 (Feb 16, 2022)
