Thread: parallel riser blocks with tramming pins
    In getting ready to mill the edge of an 8ft I beam I needed to raise it enough to clear the hand wheels of the bed and at the same time be able to maintain a reasonable tram while having to shift it along its length.
    I have a couple of 1 1/2" square bars that are key-stock quality in squareness but had been painted. First I cut a couple 7" long pieces removed the paint then cut 2 pieces of 3/4 cold roll round stock and drilled them to 1/2" on the lathe then loosely bolted these to thew mill table
    After placing the I beam on the blocks I trammed it to the table by tapping on it until it was against both pins then tightened the bolts to keep the tramming pins and the riser blocks in place
  2. The Following 5 Users Say Thank You to Frank S For This Useful Post:
    JDrouin (Feb 20, 2022), Jon (Feb 18, 2022), mwmkravchenko (Feb 16, 2022), NortonDommi (Feb 19, 2022), Toolmaker51 (Feb 16, 2022)
    Thanks Frank S! We've added your Parallel Riser Blocks with Tramming Pins to our Milling category,
    Thes riser blocks with tramming pins worked exceptionally well since I had a pair of 8 ft long beams, I needed to mill about 1/4" off the entire length of 1 flange Nothing critical dimension wise, as long as they were somewhere within .010" to .020" over the length was fine with me. I didn't want to torch or plasma the flanges off since the heat would have caused warpage and that much grinding is one of those "I ain't the one" tasks.
    North Island, New Zealand.
    NortonDommi's Tools
    "I ain't the one"
    Quote Originally Posted by NortonDommi View Post
    "I ain't the one"
    You like that do you? I stole it from a kid who used to work for me. every time we had a hard task that needed doing, I would usually ask for a volunteer. He would be the first to yell out I ain't the one for this one boss, Or if something got screwed up around the shop, he would always say I ain't the one boss. It was so comical I would usually have a comeback like yeah I'll just bet you're not, do it anyway or get it fixed.
