Results 1 to 7 of 7
Thread: Patching drywall holes - GIFs
    Patching drywall holes.
    Drywall cutout saw - GIF
    Drywall sander with LED light - GIF
    Magnetic drywall cutter - GIF
    Drywall stripper - GIF
    Drywall mud box taping tool - video
    Vintage worker installing drywall with axe - GIF
  2. The Following 4 Users Say Thank You to Altair For This Useful Post:
    johncg (Jan 6, 2022), mwmkravchenko (Jan 2, 2022), nova_robotics (Jan 5, 2022), Ralphxyz (Jan 5, 2022)
    Supporting Member Inflight's Avatar
    Dec 2018
    Inflight's Tools
    This method would never hold up in a rental property. Should've used a wooden block backer, screwed into the drywall, before attaching the drywall filler piece.
  4. The Following User Says Thank You to Inflight For This Useful Post:
    Perth Ontario Canada
    Quote Originally Posted by Inflight View Post
    It's exactly what gets done in rentals around here. Quick and cheap lipstick on a pig kind of work. Doing it right costs more.
  6. The Following User Says Thank You to mwmkravchenko For This Useful Post:
    Frank S (Jan 2, 2022)
    Mar 2013
    Perth Western Australia
    Peter Sanders's Tools
    Exactly right, do the repair PROPERLY! It's not difficult to do a GOOD job instead of a cheap fix.
  8. The Following User Says Thank You to Peter Sanders For This Useful Post:
    mwmkravchenko (Jan 3, 2022)
    Mar 2013
    Quote Originally Posted by mwmkravchenko View Post
    it is MINIMAL extra cost to do the job PROPERLY. What happens if the "repairer" and I use the term loosely! doesn't have a suitable sized hole saw, or if the hole is substantially irregular (larger). It then has to be done the way Inflight stated, the correct way (and I agree).
    Apart from doing the job correctly, the nett result of a correctly applied repair, is a less visible repair. This method leaves a "huge" patch on the wall, when a proper repair leaves almost no patch and certainly no large "lump" on the wall.
  10. The Following User Says Thank You to Peter Sanders For This Useful Post:
  11. #6
    I've seen much worst repairs though. Like just packing the hole with crumpled paper then plastered over it
  13. #7
    Sep 2018
    nova_robotics's Tools
    Hey Inflight, do you run that Tech Ingredients Youtube channel? If so there's an idea for a video.
