Simple easy-to-make table saw jig that will let you cut perfect dados and rabbet with only the use of a single table saw blade. I had some leftover pieces from my last project. So I decided to make something out of it. This woodworking jig is made from scrap plywood and a few bits of hardware found in almost every workshop. Once set the Kerfmaker right, it works perfectly every time. Easy and repeated make dado slot & rabbet Joint
