Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
Thread: Plug in drilling spindle for the tailstock.
    Dec 2017
    Cape Coral, FL
    old_toolmaker's Tools
    olderdan,
    Nice and handy for small holes and can be mounted quickly. I have a couple of 1/4" Supreme drill chucks that have never been used. Now I have a future project.
    Thanks for sharing!
    Dick
    Links to some of my plans:
  2. The Following User Says Thank You to old_toolmaker For This Useful Post:
    olderdan (Jun 28, 2019)
  3. #12
    I achieve the same high speed drilling or grinding with either an air turbine or electric spindle mounted to the tool post.
    Plug in drilling spindle for the tailstock.-airgrinder-lathe.jpg Plug in drilling spindle for the tailstock.-spindle-lathe.jpg Click images for full size.
  4. The Following 3 Users Say Thank You to tonyfoale For This Useful Post:
    Jon (Jun 26, 2019), olderdan (Jun 28, 2019), Saltfever (Jun 26, 2019)
  5. #13
    Supporting Member carl blum's Avatar
    Nov 2021
    Charleston, South Carolina
    carl blum's Tools
    Hi Gang:
    I helped rebuild a multi station machine that worked like that. For some reason spinning the part and the drill tends to make more concentric holes??
    Carl.
  6. #14
    Nov 2021
    carl blum's Tools
    Hi Gang:
    I help rebuild a machine for drilling valves for gasoline injectors. To keep the holes centered the machine spun both the valve seat and the drills. I don't know why but it kept the drill from wandering and also maintained a good cutting speed. It was quite a machine: twelve chucks holding the parts vertical, one load station, one unload station and ten working stations. Flood coolant for all, the machine was in a Plexiglas case to keep the operator dry.
    Carl.
