Results 1 to 10 of 16
Thread: Pneumatic nibbler cutting steel - GIF
    Pneumatic nibbler cutting 3/16" steel.
    HOMEMADE NIBBLER || Let's Learn Something
    Homemade metal nibbler stand - video
    Giant slip roller - GIF
    Hot strip mill slab feed table - GIF
  2. The Following 11 Users Say Thank You to Altair For This Useful Post:
    Andyt (Jan 12, 2020), baja (Jan 8, 2020), clydeman (Jan 11, 2020), greyhoundollie (Jan 7, 2020), KustomsbyKent (Jan 7, 2020), mwmkravchenko (Jan 7, 2020), olderdan (Jan 7, 2020), Seedtick (Jan 7, 2020), thehomeengineer (Jan 7, 2020), Tonyg (Jan 10, 2020), Toolmaker51 (Jan 12, 2020)
    olderdan's Tools
    Thats impressive,I did not know a nibbler could cut metal that thick, it would be useful to know the make of tool used.
  4. The Following User Says Thank You to olderdan For This Useful Post:
    Nov 2015
    It looks like a UNITEC
  6. The Following User Says Thank You to markonevet For This Useful Post:
    May 2018
    Boring, OR
    CharlesWaugh's Tools
    Yup! Unitec:
    https://www.csunitec.com/saws/electr...ers-and-shears
    For cutting sheet metal, steel plate, weldments and double sheets
    Cuts steel up to 3/8" thick and aluminum up to 1/2" thick
    Head can be rotated to four 90° positions
    Cut over 90° bends with optional die
    Charles Waugh
    www.charleswaugh.com
  8. The Following 4 Users Say Thank You to CharlesWaugh For This Useful Post:
    clydeman (Jan 11, 2020), greyhoundollie (Jan 7, 2020), Jon (Jan 7, 2020), mwmkravchenko (Jan 7, 2020)
    Supporting Member McDesign's Avatar
    Sep 2016
    McDesign's Tools
    Wish they'd freakin' tell you how much it costs. WTF is it a secret?
  10. The Following User Says Thank You to McDesign For This Useful Post:
    bigtrev8xl (Jan 8, 2020)
  11. #6
    May 2018
    Boring, OR
    https://www.mmtoolparts.com/store/cs...t-min-cs-500-e
    Lists a model that'll do 3/16" plate at roughly $3300
    Charles Waugh
  12. The Following User Says Thank You to CharlesWaugh For This Useful Post:
  13. #7
    Oct 2016
    Trumpf makes some also
  14. #8
    I frequently use a Makita nibbler but it is pushing the limits to cut 1.5 mm mild steel sheet.
    The noise from one that cuts 3/8" plate must be horrendous.
  15. #9
    years ago I had a Bosch that would do a quarter inch (6mm) in steel, It wasn't too bad....more of a thudding. It was actually a Trumph with a big Bosch grinder motor. Took 2 men and a horse to run it though.
  16. #10
    Oct 2016
    old kodger's Tools
    I have a Makita nibbler that will cut 3.2mm steel and 1.6mm stainless, about 30 years ago it cost about $300. At about the same time a fellow boat builder bought a 3/16" nibbler second hand for about $700 I think it might have been a Wolf (when Wolf made good tools)
