bobs409 (Jul 7, 2017), Flotsam (Oct 2, 2017), greyhoundollie (Feb 2, 2019), rdeg (Nov 5, 2020), Seedtick (Jul 7, 2017)
The following pictures should help. The entire frame is mounted to the board by two pieces of angle iron.
A piece of 3/8 in bar threaded on the ends is passed through a piece of 3/8 in pipe to be the hinge. Tightening of the nuts sets the friction level to allow the saw to hold its vertical position, wherever it is moved.
Flotsam (Oct 2, 2017), hilerioal@outlook.com (Jul 13, 2017)
Thanks J_P! We've added your Portable Bandsaw Stand to our Metalworking category,
as well as to your builder page: J_P's Homemade Tools. Your receipt:
J_P (Jul 11, 2017)
This is absolutely terrific and just what i was looking for. You didn't mention the brand of portable band saw but it looks like Harbor Freight's Chicago Electric model. I just bought one but the new ones are branded as Bauer. Any chance you could post some additional detail pictures of how the saw mounts to the frame? I think you mentioned that no permanent mods are made to the saw so I am assuming you either clamp around the handle(s) or use longer screws to tie the saw to the frame.
Really like how you constructed the hinge out of the pipe. I assume that was pre-threaded?
Many thanks!
Mine is the HF Chicago Electric bandsaw. I believe the Bauer is a virtual copy.... it looks like Harbor Freight's Chicago Electric model. I just bought one but the new ones are branded as Bauer. Any chance you could post some additional detail pictures of how the saw mounts to the frame?
The front and back ends of my top frame are made from angle iron. Holes were drilled in the angle iron to match the width of the ubolts. The ubolts were wrapped over the handles, vertically in the front and horizontally in the back.
Front attachment.
Looking at the front handle from the top
Back attachment
Looking at the back handle from the top
The 3/8" pipe and 3/8" roundstock were surplus materials I had on hand. I added threads to the ends of the roundstock for this project.Really like how you constructed the hinge out of the pipe. I assume that was pre-threaded?
herman43 (Jan 14, 2021)
