Results 1 to 9 of 9
Thread: Post setting method - GIF
    May 2024
    nova_robotics (Jun 24, 2025), terence b (Jun 24, 2025), thadrodgers (Jun 28, 2025)
    bruce.desertrat's Tools
    Well, so long as all that suspended-in-midair framing is plumb...
  4. The Following User Says Thank You to bruce.desertrat For This Useful Post:
    bob_3000 (Jun 24, 2025)
    Supporting Member gatz's Avatar
    gatz's Tools
    right, doesn't show any fill; how does that work ?
    Supporting Member bob_3000's Avatar
    Aug 2020
    Quote Originally Posted by gatz View Post
    He is demonstrating his method of holding and stabilizing the post with one hand, not building a whole deck.
  7. The Following User Says Thank You to bob_3000 For This Useful Post:
    Frank S (Jun 24, 2025)
    gatz's Tools
    not a good demonstration if not applicable
    Aug 2020
    His method worked perfectly did it not?
    gatz's Tools
    Title is Post SETTING method.
    How then, is the post SET; it's only located.
    Aug 2020
    Title is Post SETTING method. How then, is the post SET; it's only located.
    If you have an issue with the title and not the method then maybe just say that.
    If then have enough structure in place and anchored to support those posts, it is not difficult to put concrete in the hole AFTER hanging the post.
    As long as you take the time to work the concrete under most of the post. You may not get full wood to concrete contact, you it is easy to get enough to support the load. One problem with doing it that way it dirt falling into the open home, then not bothering to remove it before the concrete.
    The concrete should also NOT fill the hole, only fill in under the post, and a little up the side.
