Results 1 to 4 of 4
Thread: Press brake with bump and form tooling.
    Berkshire UK
    thehomeengineer's Tools
    Hi All
    I decided to make a press brake to help bend, fold and form sheet metal parts for my Foden Steam Wagon and any other jobs that need forming in the future.
    Initially in my head it started as a quick and simple build, trying to utilise materials that I had already around the shop. The further I got into the thought process I realised this was not going to be the case. If I was going to future proof the design and have something I would be happy with and do all the things I wanted. I didn’t have all the materials I needed. A couple of hundred pounds later, delivery of the parts and stock needed to get started.
    The basic frame of the machine is standard like most other builds, with a base plate, two guide shafts and a bridge piece to hold the press tooling. The tooling is 1/2” plate different widths. Also a few form tools for larger radius’s which also double up as a bump tool for extra large radius’s and shapes.
    As it is difficult to use a standard hydraulic press when bumping a large radius as the same depth/pressure is needed to be applied for a consistent form two adjustable stops were made to control the travel of the ram.
    The other additional part is an adjustable back stop which I will do a separate post on.
    The photos below show the completed brake press and it being used.
    Press brake with bump and form tooling.-img_9809.jpeg Press brake with bump and form tooling.-img_9816.jpeg Press brake with bump and form tooling.-img_9817.jpegBrake press with different tooling
    Press brake with bump and form tooling.-img_9810.jpegAdjustable bump stop to set constant depth of bump tool.
    Press brake with bump and form tooling.-img_9632.jpeg Press brake with bump and form tooling.-img_9634.jpeg Press brake with bump and form tooling.-img_9633.jpeg Press brake with bump and form tooling.-img_9635.jpeg Bump tool used to form an oval to round funnel shape.
    Press brake with bump and form tooling.-img_9818.jpeg Press brake with bump and form tooling.-img_9812.jpegBump tooling and form tooling
    Press brake with bump and form tooling.-img_9645.jpeg Press brake with bump and form tooling.-img_9644.jpeg Press brake with bump and form tooling.-img_9646.jpegForm tooling creating oval shape.
    Press brake with bump and form tooling.-img_9650.jpeg Press brake with bump and form tooling.-img_9651.jpeg Press brake with bump and form tooling.-img_9690.jpegCompleted safety valve cover.
    Press brake with bump and form tooling.-img_9699.jpeg Press brake with bump and form tooling.-img_9700.jpegBoth form tooling and bumping tool was used to create this part of the Foden water tank.
    As sheet metal isn’t my strongest discipline this has improved my skill level in forming sheet metal. I am so happy with the result of this tool and hope you have found it of interest. I haven’t tried bending 90 degree folds yet but I am sure the tool will cope.
    Again thank you for viewing
    The Home Engineer
  2. The Following 6 Users Say Thank You to thehomeengineer For This Useful Post:
    brianr47 (May 15, 2026), emu roo (May 15, 2026), Jon (May 14, 2026), mwmkravchenko (May 15, 2026), nova_robotics (May 15, 2026), Rangi (May 18, 2026)
    Thanks thehomeengineer! We've added your Press Brake to our Brakes and Presses category,
    Feb 2026
    Awesome
    Very very good detailed job. Gotta give credit or credit due and this is one of my top 10. Granite I’ve only been on here for a little while, but that is a very clean quality job and the end results are just perfect. But what else are we gonna expect from a Machinist? Keep on keeping on and everybody needs to remember we’re the boss and that machine ain’t gonna win.
ID:	50634 Click image for larger version.
ID:	50635 Click image for larger version.
ID:	50636Brake press with different tooling
ID:	50641Adjustable bump stop to set constant depth of bump tool.
ID:	50639 Click image for larger version.
ID:	50637 Click image for larger version.
ID:	50638 Click image for larger version.
ID:	50640 Bump tool used to form an oval to round funnel shape.
ID:	50642 Click image for larger version.
ID:	50651Bump tooling and form tooling
ID:	50643 Click image for larger version.
ID:	50644 Click image for larger version.
ID:	50645Form tooling creating oval shape.
ID:	50646 Click image for larger version.
ID:	50647 Click image for larger version.
ID:	50648Completed safety valve cover.
ID:	50649 Click image for larger version.
ID:	50650Both form tooling and bumping tool was used to create this part of the Foden water tank.
    The Home Engineer[/QUOTE]
  6. The Following User Says Thank You to amaezing For This Useful Post:
    thehomeengineer (May 23, 2026)
    Berkshire UK
    Hi Amaezing
    Thank you for the kind words. This is a great forum for all kinds of ideas and support. I am glad you are enjoying the being part of the community.
    The Home Engineer
