Results 1 to 9 of 9
Thread: Propane tank valve removal holding fixture - photo
  1. #2
    I do not know about other countries but here in Spain the valves on these bottles are soft soldered in place for 100% sealing and will unscrew easily if heated enough to soften the solder. I did not know this until after I struggled to remove my first one, then I could see why.
    Of course it is best to ensure that the bottle has been well drained and vented first.
    These bottles have numerous uses. I have used them for the media in blasting applications, sand and sodium bicarbonate. They can be used as compressed air cylinders which can be filled from a compressor at base and then taken into the field without the weight and bulk of a compressor. Their usefulness is only limited by imagination.
  2. The Following 2 Users Say Thank You to tonyfoale For This Useful Post:
    NortonDommi (Apr 27, 2021), olderdan (Jan 26, 2020)
