Results 1 to 10 of 11
Thread: A quick alternative to mill tramming
    Dry Gulch, Tx
    Crusty's Tools
    Thumbs up A quick alternative to mill tramming
    Do you find yourself using less than optimum approaches to remove metal because you don't want to tram your mill in again afterwards? I know I did until I adopted this procedure that Keith Rucker uses instead of tramming his mill. He uses a cylindrical square directly against the quill of his mill to set it exactly square to the table (the objective of tramming) but those are really expensive.
    I used a precision shaft chucked in the spindle (I think highly of Thompson QS precision shafting) and one of a pair of 2-4-6 blocks that I bought for this purpose (as well as other setup uses) and my mill was trammed better in 5 minutes than I had previously done with an indicator on a bar in the spindle. The 2-4-6 block is eased against the chucked shaft with a bright flashlight directed from behind and you can easily see .001" out of square like this, and this method when completed is close enough to perfectly square that a surfacing cutter leaves cross marks in the milled surface. Use a portion of the block where the surface is continuous and not interrupted by the holes in the block.
    All in I think I've got less than $100 in this method as well as some more useful items for setup.
Name:	tramming alternative.jpg
  2. The Following 27 Users Say Thank You to Crusty For This Useful Post:
    albertq (Mar 1, 2025), boxofrogs (Dec 24, 2021), clydeman (Apr 22, 2025), EclecticNeophyte (Feb 24, 2020), elk-a-holic (Feb 16, 2020), emu roo (Mar 1, 2025), freddo4 (Feb 14, 2020), Greasy joe (Feb 23, 2020), Home-PC (Dec 24, 2021), JDrouin (Dec 24, 2021), joe_d241 (Feb 24, 2020), Jon (Feb 17, 2020), MasterMaker (Feb 15, 2020), melbakid (Dec 24, 2021), mr mikey (Mar 2, 2025), mwmkravchenko (Feb 14, 2020), NortonDommi (Feb 18, 2020), nova_robotics (Dec 25, 2021), odd one (Dec 24, 2021), Ralphxyz (Apr 25, 2026), rdarrylb (Feb 15, 2020), rebuilder1954 (Mar 1, 2025), RetiredFAE (Apr 25, 2026), Scotsman Hosie (Feb 15, 2020), suther51 (Feb 14, 2020), Tonyg (Apr 24, 2025), Toolmaker51 (Dec 24, 2021)
