Results 1 to 10 of 12
Thread: Rapid Exchange Multi Tool Drill Press Table
    Mar 2014
    Houston, TX
    shopstorm's Tools
    I have a custom woodworking table on my drill press. I use it 75-80 percent of the time. But it feels like I am constantly removing it to do some odd metal work or something the table doesn't support. When done, I have to reverse the process and replace whatever accessory I needed with my wood working table setup. Not the biggest problem in the world .... but it always takes a few valuable minutes to swap out.
    With this setup I have a second tool surface that allows a rapid exchange. Now I never have to remove and reinstall my wood working table. I don't have the $ or space for a second drill press, so for me it's great.
    In the video you can see how smooth the rotational action is. The guide pin system locks previous positions in with great accuracy. Usually I leave the second surface open, but in this case I had a low cost cross slide vice on it.... so I just left it in place versus removing and storing.
    Rapid Exchange Multi Tool Drill Press Table-43dp.jpgRapid Exchange Multi Tool Drill Press Table-47dp.jpgRapid Exchange Multi Tool Drill Press Table-45dp.jpg
  2. The Following 14 Users Say Thank You to shopstorm For This Useful Post:
    baja (Aug 28, 2019), Dirk Schuurmans (Feb 29, 2016), emu roo (Jul 26, 2024), flyfr8rs (Oct 6, 2021), Jon (Sep 27, 2014), kbalch (Sep 25, 2014), lazarus (Jun 13, 2016), luvmygto (Oct 6, 2021), mountiebuff (Oct 7, 2021), oldcaptainrusty (Dec 14, 2017), Paul Jones (Jun 13, 2016), Quinton 357 (Aug 27, 2019), rdarrylb (Oct 7, 2021), Tuomas (Jun 13, 2016)
    That's a nice system shopstorm. And that locking mechanism looks pretty smooth.
    shopstorm (Sep 25, 2014)
    Mar 2014
    Houston, TX
    shopstorm's Tools
    Thanks! I really appreciate the feedback.
    Quote Originally Posted by DIYer View Post
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks shopstorm! I've added your Multi Tool Drill Press Table to our Drilling and Drill Presses category, as well as to your builder page: shopstorm's Homemade Tools. Your receipt:
  7. The Following User Says Thank You to kbalch For This Useful Post:
    Mar 2014
    Houston, TX
    shopstorm's Tools
    As additional notes.
    The unit is all steel, except for the woodworking table, which is a separate component.
    The unit itself replaces the stock table. The single mounting bolt from the stock rack is repurposed to attach a bearing post. A carriage rotates around the post and supports the tool/drilling surfaces. Surface positions are located and locked in using a very precise guide pin system. The surfaces are completely variable, so you essentially have two drill press tables to configure.
    I usually leave one blank and the other surface houses my wood table.
    San DIEGO, California
    Captainleeward's Tools
    WOW flip the chip Great idea. :O)
  10. The Following User Says Thank You to Captainleeward For This Useful Post:
  11. #7
    Mar 2014
    Houston, TX
    shopstorm's Tools
    Quote Originally Posted by capainleeward View Post
    Thanks for the comment.
    This was in another post of mine, but the same core system can be added to a bench as well.
    Take a look at my grinder and vice setup.
  12. The Following User Says Thank You to shopstorm For This Useful Post:
  13. #8
    Another great shopstorm tool build!
    I see you've got a nice website up at ShopStormTools.com. When do we get to see these tools hit the market? Is there a Kickstarter for them? If you do end up crowdfunding them, I'd be interested in being a backer.
  14. #9
    Functional and aesthetically-pleasing. The contrasting wood looks really nice. Well engineered and executed shopstorm.
  15. The Following User Says Thank You to Altair For This Useful Post:
    shopstorm (Sep 29, 2014)
  16. #10
    Mar 2014
    Houston, TX
    shopstorm's Tools
    Thanks.
    I will keep you posted. I filed a patent for the function a few months ago. I have been trying to get feedback to further refine the design, so I appreciate comments. I will definitely keep you posted. My e-mail is on that site, so feel free to reach out to me directly as well.
