Results 1 to 5 of 5
Thread: Ratchet Bar Clamp
    Supporting Member Bellevue Woodshop's Avatar
    Mar 2018
    Norway
    Bellevue Woodshop's Tools
    Ratchet Bar Clamp
    Ratchet Bar Clamp
    I wanted to try to make a clamp from mostly wood (except for the threaded rod of course)
    So I made this Ratchet Bar Clamp from a 3/4" baltic birch plywood bar, and notched it like a sawblade.
    I could then make the sides of the sliding tail stock from 5/8" baltic birch plywood, and a lever for a movable stop.
    The stop lever for the notches are spring loaded with a rubber band.
    The head stock (with the threaded rod) is also laminated from 5/8" and 3/4" BBP, and pinned with dowels
    I tapped the threads directly into the wood, and this far it still works great after plenty of use.
    I lubed it with some candle wax. If it strips, I just insert a T nut.
    The handles are made from 1" wood dowels with foam bicycle handle grips on it.
    I made a video on building this clamp:
    Want more homemade tools inspiration? Visit my website: www.bellevuewoodshop.com
    Facebook: Bellevue Snekkeri
    Instagram:bellevuewoodshop
  2. The Following 12 Users Say Thank You to Bellevue Woodshop For This Useful Post:
    billster (Jul 19, 2018), glenntref (Apr 2, 2018), gunsgt1863 (Jul 25, 2018), Jon (Mar 20, 2018), oldcaptainrusty (Mar 21, 2018), Paul Jones (Mar 22, 2018), Philip Davies (Jul 21, 2024), PJs (Mar 20, 2018), rossbotics (Mar 21, 2018), Seedtick (Mar 21, 2018), Ultimaest (Mar 27, 2018), volodar (Jul 19, 2018)
    Dec 2013
    Florida
    rossbotics's Tools
    Kool, great work
    Comments are always welcome
    Doug
    Thanks Bellevue Woodshop! We've added your Ratchet Bar Clamp to our Clamps category,
    as well as to your builder page: Bellevue Woodshop's Homemade Tools. Your receipt:
    Mar 2018
    Norway
    [QUOTE=DIYer;109206]<!-- BEGIN /var/www/html/homemadetools/protected/modules/zeus/views/tool/postUpdate.php -->
    Thanks, I made a reply to you in my other thread about my builders page: http://www.homemadetools.net/forum/a...e-stop-66910-2 post #16
    Mar 2018
    Norway
    Thanks Doug
    Best reg
    Roy
    Download plans for clamps.
