Results 1 to 6 of 6
Thread: Re - ground Blacksmith drills
    Dec 2015
    Reading, Berks, UK
    Philip Davies's Tools
    I am seeking advice about some drills I have got, which have not been used since they were re - ground, although their shanks show heavy scarring.
ID:	39137Click image for larger version.
    The larger on the left seems to be a slot cutter
ID:	39139 Click image for larger version.
    The smaller looks as though it is for drilling
    But if so, what material?
    I should like to experiment with these on a variety of materials (and, yes, I do know that material must be secured firmly)
    I do not think that I will use the good keyless chuck on my drill, but will use a spare, but do you think I might damage the spindle if I am too rash?
    I have bought a compound table and vice so can move very cautiously and will select the lowest speed at first. I shall start with acrylic, then aluminium and then possibly brass or even steel.
    What do you think? As ever, very grateful for your advice.
  2. The Following User Says Thank You to Philip Davies For This Useful Post:
    Home-PC (Apr 8, 2021)
