Thread: Re-think, pulley tension adjustment for bead roller and slip rollers
    Berkshire UK
    thehomeengineer's Tools
    Hi All
    After receiving the vee-belts in the post I soon realised the eccentric plummer block would not offer enough adjustment to tension both belts. So a re-think was needed and a solution to this problem.
    I decided to manufacture a hinge plate the plummer block could be bolted too and operated via a single screw to tension the belts in conjunction with the motor adjustment and the eccentric plummer block. The eccentric was also difficult to adjust so a handle was made to rotate the shaft.
    Link to previous post.
    Powering homemade sheet metal tooling (Table and motor arrangement)
    The photos below show the solution.
Name:	IMG_4382 painted.jpg
    Painted components ready for assembly
Name:	IMG_4385 4 jaw setup.jpg
ID:	33272 Click image for larger version.
Name:	IMG_4386 machined.jpg
    Eccentric casting housing machined to accept operating lever.
Name:	IMG_4387 drilling handle.jpg
    handle drilled and tapped at angle to give clearance on plummer block body. This tapped hole also locks the handle to casting.
Name:	IMG_4392 simple hinge.jpg
    The base plate was made from 6mm aluminium and the hinge was made from another piece of 6mm plate bolted together and drilled on joint center line to accept 8mm pin.
Name:	IMG_4389 part assembled.jpg
    Screw showing additional adjustment
Name:	IMG_4388 ready for eccentric.jpg
    Ready for final assembly
Name:	IMG_4393 pulley side.jpg
ID:	33278 Click image for larger version.
Name:	IMG_4394 eccentric lever side.jpg
ID:	33279Click image for larger version.
Name:	IMG_4391 completed assembly.jpg
    Fully assembled
Name:	IMG_4396 in position.jpg
ID:	33281 Click image for larger version.
Name:	IMG_4395 linked to motor.jpg
    Bolted to underside of table top
    After setting up, the belts can be tensioned relatively easy and a new length belt for the bead roller is need as the one i purchased is to short but the slip rolls worked out a treat and have had them rotating via the drive.
    New belt on order for bead roller.
    Thank you for viewing
    Thw Home Engineer
  2. The Following 8 Users Say Thank You to thehomeengineer For This Useful Post:
    baja (Jan 28, 2020), Christophe Mineau (Jan 27, 2020), emu roo (Oct 29, 2025), high-side (Jan 27, 2020), Jon (Jan 27, 2020), Philip Davies (Jan 28, 2020), Scotsman Hosie (Feb 2, 2020), threesixesinarow (Jan 27, 2020)
