Thread: Rebuild worn gear teeth with TIG welding - GIF
    May 2024
    Rebuild worn gear teeth with TIG welding.
    Cutting bevel gear teeth - GIF
    Cutting gear teeth using a shaper - GIF
    Cutting nylon gear teeth - GIF
    Cutting sprocket teeth - GIF
    mr mikey (Feb 1, 2026), nova_robotics (Jan 31, 2026)
    Sep 2018
    nova_robotics's Tools
    I've done that a few times. It should be considered a temporary bandaid at best. I have a shop with half a dozen CNC machines and I can't re-cut those teeth. It turns into a die grinder job, and then you get lumpy noisy gears.
    Isambard's Avatar
    Aug 2019
    Hawke's Bay, New Zealand
    LOL. That tooth isn't worn, it has been bruised, by some loose extraneous metal passing through...
    All it needs is some attention with a die grinder, with the syncro cone has been welded is anyone's guess...
  5. The Following User Says Thank You to Isambard For This Useful Post:
    nova_robotics (Feb 1, 2026)
