There's value engineering which every engineer should understand, and there's intentionally designing a part to fail. Now, there may be a safety reason to have one part fail after XXXX uses in order to cause the device to be tossed before something dangerous fails.
Then there's companies like HP (the current, not the old one). They are known for things like automatically tracking the serial number of printer ink cartridges. If you take a cartridge out of one printer, refill it, and stick it in another... the new printer will complain that the cartridge is registered to another printer and may refuse to print. This is carrying things a bit far.
There's also the eternal battle with production departments. There was a time I designed medical equipment, they complained the production units didn't work right. It turns out they had replaced the high price precision parts with ones the guy at the local electronics store told them were a direct replacement. They also gave doctors the special wrenches to open the device because they didn't buy the latching cable connectors I specified and so cables would fall off in shipping. I left them before they killed someone, they did shock at least one patient.
