Results 1 to 5 of 5
Thread: Removing an engine from an airplane - GIF
    May 2024
    emu roo (Jul 19, 2025), nova_robotics (Jul 19, 2025)
    Oct 2012
    Lafayette, Indiana
    sossol's Tools
    It amazes me that all of the thrust from and all of the weight of the engine is carried through only three mounting pins, and that those pins are engineered to fail so that the engine falls off to prevent wing damage.
    The amount of thought that goes into making planes work safely is mind-boggling even before considering the fact that it's all hidden under a boring appearance.
    Neil
    Jul 2018
    Flora, MS
    Floradawg's Tools
    One of the things that doomed the DC 10 as a passenger carrier is when one of the engines came off the wing and the plane crashed. Douglas had designed a special device, probably something like the one they're using here. It was emphasized that it had to be done using it. A repair crew found out it was quicker and easier to use a forklift. They had the forklift supporting the engine but not completely disengaged from the pylon. They went to lunch and while they were gone the forklift allowed the engine to drift down some. This caused a crack in a support pin on the pylon. They weren't aware of it. Afterwards the plane had a bad reputation for no good reason. Everything was okay after it was known that they couldn't do that. Thereafter the plane was used primarily as a cargo carrier. I either read something about it or saw something in a program on TV. As I remember it, it happened this way.
    Oct 2012
    Lafayette, Indiana
    sossol's Tools
    Quote Originally Posted by Floradawg View Post
    I saw a plane crash investigation video about this. Those techs were just lazy. All engine families have bespoke cradles for techs to use for installation/removal, but it takes a long time to set up properly.
    Neil
  6. The Following User Says Thank You to sossol For This Useful Post:
    Floradawg (Jul 26, 2025)
    Mar 2018
    Hoosiersmoker's Tools
    And they're all wearing shoes that cover their feet! Not one sandal in the group!
    "The man who views the world at 50 the same as he did at 20 has wasted 30 years of his life."
    - Muhammad Ali
