Need to remove mill scale? I show you how to do exactly that and I even show you an option of protecting the steel once your done with it.
https://www.youtube.com/watch?v=avFUb80gsvY
Like the Vinegar method , thanks
Thanks Haslip Cycle Works! We've added your Mill Scale Removal Methods to our Metalworking category,
as well as to your builder page: Haslip Cycle Works's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-mill-scale-removal-methods"> <img src="/uploads/247757/homemade-mill-scale-removal-methods.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-mill-scale-removal-methods">Mill Scale Removal Methods</a> <span> by <a href="https://www.homemadetools.net/builder/Haslip+Cycle+Works">Haslip Cycle Works</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/cleaner'>cleaner</a>, <a href='https://www.homemadetools.net/tag/metalworking'>metalworking</a> </div> </div> </div> </div>
I like the vinegar method for several reasons.
1. it is less costly
2. less hazardous
3. easier to dispose of (I dump it on the weeds out back)
4. it works fairly well. it just takes longer is all.
Here are some things I have found to make a difference in using vinegar
1. For some reason, heat and light seem to make vinegar more "aggressive" on the surface of the metal, thus it seems to work a little bit better/faster if left out in the sun.
2. vinegar is available in different levels of acidity. Regular vinegar is usually 5 percent, pickling vinegar is 6 percent, and cleaning vinegar is 30 percent acidity.
3. vinegar will also etch/remove the zinc off of galvanized metal so it will take paint.
WARNING!!!!!!! IF SPILLED ON YOUR CONCRETE FLOOR IT WILL EAT INTO IT VERY QUICKLY!!!!!! (don't ask how I found out that even regular 5 percent vinegar will do it to it ;) ).
