Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
Thread: Resistors for current measurement
    I'm always nervous wiring my good VOM in series into a circuit to measure current. Another way to measure current is to measure voltage across a resistor that is series wired into the circuit in question. This way the VOM remains in high impedance mode and so is less susceptible to damage.
    Most circuits will not be adversely affected if the series resistor is very small in comparison to the circuit resistance itself. OTOH, the resistor must be large enough to produce an easily measured voltage when the current is flowing through it.
    I acquired three 50 watt, 1% resistors in resistances of 0.1, 1.0, and 10.0 ohms and attached them to a large aluminum plate to act as a heat sink.
    Given 50 watt capability, the maximum current and associated voltage for each resistor is...
    ohms amps volts
    0.1 22.4 2.24
    1.0 7.1 7.1
    10.0 2.24 22.4
    Home Shop Freeware
    Paul Jones (Feb 19, 2019), ranald (Feb 18, 2019), Scotsman Hosie (Feb 19, 2019), Seedtick (Feb 18, 2019)
    Jan 2018
    Black Mountain Queensland
    ranald's Tools
    I'll never do it but it is interesting. Thanks for sharing Marv.
    Nov 2015
    Marv i may be wrong but i think an unpainted aluminum surface, better even with a little thermal compound should work better
    Ariscats
    Quote Originally Posted by Ariscats View Post
    You're correct, of course, but that bit of aluminum was lying around, I was in a rush, and all my applications involve currents far below the 50 watt limitation.
    Home Shop Freeware
    Nov 2015
    O.K. Marv. I just made a comment.
    Ariscats
    You made me feel guilty (and I deserve to be) so a few minutes with a sanding drum and we have some nice bare radiative surfaces...
    Home Shop Freeware
  8. #7
    Sep 2012
    Hinchinbrook QLD
    The use of resistors in this situation is called a "shunt"
    Another method for measuring high current draw is to measure across the supply lead that oft times goes from the power source directly to the load. Disconnect, and, accurately measure the resistance of that lead, and you have a "known" shunt value. Reconnect, and then measure the current draw and you achieve the same result
    Cheers Phil
  9. #8
    Nov 2015
    Don't forget the compound. Otherwise! LOL
    Ariscats
  10. #9
    Thanks mklotz! We've added your Current Measuring Method to our Measuring and Marking category,
  11. #10
    Supporting Member Scotsman Hosie's Avatar
    Apr 2017
    Salt Lake City, UTAH
    Scotsman Hosie's Tools
    After the 1st number of years — and easily as many blown up meters — I discovered I could blow up a $5.oo meter, with about the same efficacy as I could a more expensive model. And since, truth be told, I rarely needed the kind of sensitivity of either a Simpson or a Fluke, I defaulted to always having an extra meter handy. Kinda like having an extra truck key. (And I probably saved a couple thousand dollars, over the last 40 years.)
    On another note, I did a helluva lot better, when I started marking the damned dials. So I could clearly tell what settings I had them on.
  12. The Following 2 Users Say Thank You to Scotsman Hosie For This Useful Post:
    Toolmaker51 (Feb 20, 2023), WmRMeyers (Feb 20, 2023)
