Results 1 to 10 of 17
Thread: Rifling Machine
    Jan 2016
    Dubrovnik - Croatia
    LMMasterMariner's Tools
    Rifling Machine
    This is my first post ever.
    RIFLING MACHINE
    10 years ago I made rifling machine of very simple design and later on when I had
    internet access, found that some more clever people did it using much better design
    and they did it in 1853. Just google '1853 rifling machine' and you will find it.
    Must say that I am seaman and at that time I didn’t have internet access on board.
    When ashore I didn’t have time for internet café. I was younger and I was spending
    most of my free time in bars, pubs, night clubs and discoteques.
    Life is much easier nowadays. Have internet on board and I no longer make bars.
    At that time I was aboard brand new cargo vessel with brand new professional
    grade lathe and milling machine. Once when I was in Hong Kong, I found Canton
    Road, the street with so many shops for all kind of tools, bearings, gears, v-belts, etc.
    You name it, they have it there. (picture 01) The street next to Canton Road is
    Reclamation street and there I found aluminum shop where they cut aluminum to
    required size and they do it immediately for additional small fee.
    As I already had idea what to do, I decided to buy parts in order to build rifling
    machine, so I spent approx. 400 US Dollars for 6 bearing housings with ball bearings,
    8 pieces linear bearings dia 20mm, 3 meters of 20mm shaft, 50cm geared rack
    2 gears (one for 9mm Luger and another for .22 LR calibers), couple of aluminum
    plates and whole bunch of bolts and nuts. Gear sizes were determined in the shop by
    turning the gear on the rack for one complete turn and measuring distance.
    Design is very simple. Changing direction from longitudinal to rotational by
    means of gear and pinion. That came for free as I took it from vessel's spares.
    These were gears and pinions of Nitto Kohki angle grinders. Extremely accurate and
    also extremely expensive, but as I said that came for free. Took me couple of months
    to complete the job. In the meantime stopped with machining aboard vessels, as at
    home I have 11 x 26 cutmaster lathe and 6 x 26 mini knee mill (harbour freight 40939).
    Both made in China but not so bad. Can’t afford any good quality machines (read heavy),
    as I have more than one hundred stairs from the street to my house. From 10 attached
    pictures it can be seen what machine looks like and pictures 09 and 10 show recent
    condition of rifling machine. These last 2 pictures were taken when I was rearranging
    my workshop. Machine is not in use anymore and I am planning to use sliding parts
    (linear bearings and shafts) to convert it to cut off saw.
    Hope that this article will help someone to build his own rifling machine.
    LMMasterMariner
ID:	7327   Click image for larger version.
ID:	7328   Click image for larger version.
ID:	7329   Click image for larger version.
ID:	7330   Click image for larger version.
ID:	7332   Click image for larger version.
ID:	7333   Click image for larger version.
ID:	7334   Click image for larger version.
ID:	7335   Click image for larger version.
  2. The Following 26 Users Say Thank You to LMMasterMariner For This Useful Post:
    albertq (Feb 12, 2024), baja (Sep 25, 2019), clydeman (Jul 22, 2022), correntinos (Apr 29, 2020), darkoford (Aug 9, 2017), DaveInPA (Jan 12, 2016), EnginePaul (Jul 22, 2022), Gromet (Sep 25, 2019), high-side (Sep 26, 2019), Jon (Jan 8, 2016), kbalch (Jan 8, 2016), Mike65 (Mar 28, 2021), nova_robotics (Jul 22, 2022), ntaryl (Feb 9, 2016), Okapi (Sep 25, 2019), old fogey (Jan 13, 2016), Oroblanco (Feb 26, 2017), Paul Jones (Jan 9, 2016), PJs (Jan 10, 2016), Ralphxyz (Feb 18, 2024), rendoman (Jan 12, 2016), Resident114 (Jul 24, 2022), Saxon Violence (Jan 13, 2016), sking0369 (Jan 8, 2016), txrascal (Feb 22, 2016), Vyacheslav.Nevolya (Mar 4, 2017)
