Thread: Ring Roller Bender with Hydraulic Assist (DIY)
Hybrid View
    Supporting Member kess's Avatar
    Dec 2015
    Thessaloniki Greece
    kess's Tools
    I decided to create this tool for my needs to bend a round bar ø12mm to build two trusses
    to reinforcing my sheet metal bender.
    It isn't a heavy duty tool but is a quick and easy build and do not required special tools or materials.
    I made it with that I had in stock and the only extra things that needed was washers M27.
  2. The Following 9 Users Say Thank You to kess For This Useful Post:
    Downeast Thunder (Feb 3, 2016), emu roo (Sep 15, 2025), Gigjoec (Feb 7, 2016), Jon (Jan 30, 2016), kbalch (Jan 31, 2016), PJs (Feb 3, 2016), Seedtick (Nov 21, 2017), Sleykin (Jun 1, 2020), Sprig1 (Feb 3, 2016)
    Thanks kess! We've added your Ring Roller Bender to our Ring Rollers category, as well as to your builder page: kess' Homemade Tools. Your receipt:
    Dec 2015
    Thessaloniki Greece
    kess's Tools
    When I decided to make a roller, my initial thought was for a very simple tool and only for the bending of two arcs for my need to make two trusses to reinforce my sheet metal brake, and nothing more.
    But after I had finished with my sheet metal brake modifications, I decided to add a second set roller-bases closer to the center roller, so my tool to be able to bend circles at smaller diameters.
    And after that, I said to myself, why not and a removable wheel handle for the rotation, it is easy to made it now.
    Ring Roller Bender with Hydraulic Assist (DIY)-01p.jpg Ring Roller Bender with Hydraulic Assist (DIY)-02.jpg Ring Roller Bender with Hydraulic Assist (DIY)-03.jpg
  6. The Following 3 Users Say Thank You to kess For This Useful Post:
    emu roo (Sep 15, 2025), kbalch (Feb 8, 2016), Seedtick (Nov 21, 2017)
