Hi,
l am looking for cheap homemade rivet nut installation tool
Regards
Hi,
Regards
Hi kgenterprises,
Welcome! :welcome:
Have you seen these: Rivnut Tools
It's dead simple to cobble something adequate together from a bolt and a couple of nuts/washers, especially if you're only doing a few aluminum rivnuts. If you need to install a large number, or if you're using steel rivnuts, then you'll likely need a sturdier tool. Depending on where you're planning to use them, you might even do better with nutplates.
What are you building?
Ken
Hi kgenterprises - welcome to HomemadeTools.net :welcome:
Hi kgenterprises, as Ken has pointed out, you'll find a ton of rivnut tools here. You're likely to find one that suits the materials you have on hand. Welcome to the forums! :)
